Old 07-13-2004, 05:03 PM   #1
willow72
willow72's Avatar
vacume leak?
can sombody tell me how too tell if my intake manifold has a vacume leak?
willow72 is offline   Reply With Quote
Old 07-13-2004, 05:33 PM   #2
cdowns
cdowns's Avatar
easiest way is with carb cleaner or wd40 while the engine is ideling lightly spray around the base of the carb and near where any gaskets are as well as the vaccum hose connections if the idel raises suddenly there's your leak don't get carried away it is after all flameable
Old 07-13-2004, 05:34 PM   #3
COBALT
COBALT's Avatar
http://67-72chevytrucks.com/vboard/s....php3?t=111589
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 07-13-2004, 06:12 PM   #4
franko72
Franko72
franko72's Avatar
this may sound silly but it has worked for me. remove the breather and place a rag over the carb. inlet .pull the biggest vac hose loose from its connection .If you smoke ciggs ,light one up and blow the smoke into the vac hose repeatedly until the chamber fills up. watch the hoses as you do this . dont pass out trying. ha. If any cracks or brittle hoses are there you will see them smoke.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
