![]() Join Date: Jul 2015
Quick question on fitment - power steering gear
Steering gear from 68 suburban?
Will this work on my conversion? Installing 74 c20 cross member and upgrading to power steering.
1963 C20, small window, long bed 292, 4-speed |
![]() ![]() ![]() Join Date: Jan 2018
Re: Quick question on fitment - power steering gear
I think the 4x4 steering gears are different, but I'm not 100% sure on that. If it was a 2wd gear, it would definitely work for ya
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Moderator
![]() ![]() Join Date: Aug 2011
Maybe the steering box itself. Nothing else. Not the pitman arm etc. Need a casting number off the box though. In fact being a 4WD the pitman arm shaft size may be too big.
But Found Her 25yrs Later!
I don't think the poster said 4x4.
I don’t recall if it was a 4x4, there wasn’t much left of it.
If the gear you are looking at getting is the gear in that picture you posted, isn't that a front axle in the background of the picture?
#7 | |
I’ll probably just keep looking; maybe I’ll just buy a new gear.
#8 | |
I snagged a ps box off a 4x4 frame a few weeks back ,dont know what year it was just the frame and the pitman arm was way different. Looks like the one in the pic. .somehow the one I snagged off the 2 wd sub. got the top cover cracked, the one that has the 4 bolts on top with the set screw. So I was able to swap those covers .
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
![]() Join Date: Oct 2013
Yes, as mentioned above, 4 and 2 WD steering gear boxes are different. One way to differentiate them is how the pitman arm attaches to the gear box.
A few photos showing 4WD pitman arm attached to steering gear box by a bolt in pitman arm going through recess in shaft, and tightening onto splines in shaft. The 2WD attaches pitman arm by a nut on bottom of shaft. Last edited by aotte1; 04-19-2021 at 01:04 AM. |
Would this one work, from a 1978 C20?
https://www.rockauto.com/en/moreinfo...032130&jsn=557 I have the 1974 Cront Cross member on my 63 C20. It is getting harder to find these power steering gear boxes, at least the cheaper used ones. What is the range of years that will work for these conversions?
![]() Join Date: Mar 2006
2WD and 4x4 steering boxes are the same with the exception of the sector shaft. I had a 1978 K10 box rebuilt and the builder swapped in a 2wd shaft. Later boxes have a variable ratio box but somewhere around 1980 they went to an o-ring fitting instead of the flare. You can swap fitting and get adapters, but it is easiest to buy similar year steering boxes and pumps so you can use stock hoses.
#13 | |
My front crossmember is from a 74, so I think it should bolt up ok. And, my power steering pump is from a 63, so I could see there being an issue with the hoses. Either way, I’ll probably have to use an adapter.
![]() Join Date: Sep 2020
Don’t let the hoses dictate what you use, the adapter to turn any of those into a #6 an is relatively cheap, then your local hydraulic shop can make whatever hose length you need, and you can put it wherever you want it, not having to deal with any factory configuration. At times this is the most cost effective route as well...
#15 |
60-66 Nut
You need a '68-'86 C series or '87-'91 R series steering box and pitman arm. The K/V series steering boxes will NOT work for a 2wd application. In 1980 the fitting style changed from SAE to Metric with an o-ring.
#16 |
Ok. I got a question...
I have a PS gearbox from a 72 C20. Do I need to purchase a new steering coupler for the 72? I am doing this conversion on my 63, I purchased the bracket from Mr Captain, also the steering coupler. Just not sure how to put the steering system back together. These are $45? Wow, thought it would be a little less.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 05-07-2021 at 10:55 PM. |
#17 |
On the coupler, you'll need to get the one that matches the splines on your steering gear. There are several different sizes, but where the column attaches to the coupler is all the same
#18 |
What about the repair kits, that should work, right?
#19 |
It worked for me, but was definitely a struggle. If I were to do it again, I'd probably just get a whole new one
#20 |
You’re right. Wasn’t easy taking it apart, so I just bought a new one.
#21 |
So, when it comes to the pressure hose, this is correct?
And, the pressure port is closest to the frame? It is the larger port in my application.
#22 | |
The actual ID of the return hose port is about 0.55”; would that make it a 3/8 AN fitting?
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 05-17-2021 at 09:54 PM. |
#23 |
Moderator
Yes pressure port nearest the frame.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 05-18-2021 at 07:18 AM. |
#24 |
Strange - none of these return lines fit. Seems like I need a regular flared fitting, like the pressure hose.
#25 |
Moderator
If that's your box in post 21 then yes you need the inverted flare fittings. Same type I used.
