Old 07-13-2004, 08:37 PM   #1
bigblock73
yeller
bigblock73's Avatar
3/4 ton ---> 1/2 ton, frames the same?
I got the following question from a visitor at 73-87.com....
Hi I hope you can help me or know someone who can.I have wrote a number of truck forums and have got so many different answers to the same question.Well here it is.I want to change my C20 to a C10 for many reasons and wanted to know if I can change the rear diff and springs and the front suspension arms,rotors calipers ect or do I have to change the whole frame.I would like to keep my frame as it is straight and solid.Also is a suburban frame the same as a pickup?
I am pretty sure the frames are identical, but before I tell him this (or show him the thread), I wanted to hear from you guys.
Let me hear what you know.
bigblock73 is offline   Reply With Quote
Old 07-13-2004, 09:26 PM   #2
plumbcut
california fill
the frames are the same. the suburban frame is much different than the truck frame though.
plumbcut is offline   Reply With Quote
Old 07-13-2004, 10:13 PM   #3
bigblock73
yeller
bigblock73's Avatar
Yes, I knew that...it was just the 3/4 to 1/2 ton frame comparison I am/was unsure of.
Thanks.
Old 07-13-2004, 10:30 PM   #4
1972C10
1972C10's Avatar
Man i done thought you ran into problems with your mounts BTW Did you ever get them in?
1972C10 is offline   Reply With Quote
Old 07-13-2004, 10:37 PM   #5
Russell
Professional Grade
Russell's Avatar
I'm fairly sure that the 3/4 ton and 1/2 ton frames are the same -- Just that a 1/2 ton has a much lighter suspension / drivetrain...
1 ton frames are different like suburban and van frames though...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 07-13-2004, 10:51 PM   #6
bigblock73
yeller
bigblock73's Avatar
I haven't pulled out the 454 yet, but I got those mounts all cleaned up and ready to go. I am going to compare them to the ones I have in there now before I drop the engine back in...I will keep you posted though.
Old 07-14-2004, 01:00 AM   #7
SanitysBane
i didn't change the mounts on my frame when i droped in my big block to replace my 305. but on another note, i think it would be alot easyer just to find a good 1/2 ton frame than trying to convert a 3/4 to a 1/2.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
