04-22-2021, 12:18 PM | #51 |
My truck has been off road for 30years, it’s a 72 Cheyenne so just getting back to it now. Interior parts, seat belts, door panels, I don’t have seats. Took it apart back then and now trying to build it back up. So what do you have? Thanks
Posted via Mobile Device |
04-22-2021, 09:30 PM | #52 | |
On the road
Re: “Castro” my new 72 build
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
04-22-2021, 11:31 PM | #53 |
Thanks anyway. Keep up the great work!
04-23-2021, 11:01 AM | #54 |
On the road
With the original hub caps and stock wheels. Took it out for a final drive as a LWB.
04-23-2021, 11:05 AM | #55 |
On the road
Random photos of the QA1 Stuff
04-23-2021, 11:07 AM | #56 |
On the road
I picked up a set of NOS rockers off the board. I have a set of repops that came with the truck, but these work way better. Old Castro will like these, they fit like a glove but are not cheap when you find them. Worth every penny for the labor you save.
04-23-2021, 11:09 AM | #57 |
On the road
Also picked up a new Big Block fan shroud and fan here off the board, mine were smashed. I wound up not using this fan and used a mid-80’s C-30 5 blade fan for a 454 or diesel and an ECP radiator.
04-23-2021, 11:11 AM | #58 |
On the road
Picked up these slick QA1 tie rod adjusters, got them on and have the sway bars installed front and rear.
04-23-2021, 11:13 AM | #59 |
On the road
Time to pull the body off, it gave a fight, but I won, front clip off and started gutting the cab for removal.
04-23-2021, 11:14 AM | #60 |
On the road
The cab on jack stands for cleaning and rust repair.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com Last edited by GSFMECH; 04-23-2021 at 11:17 AM. Reason: photos |
04-23-2021, 11:19 AM | #61 |
On the road
The original jack and handle were still in it.
04-25-2021, 12:10 PM | #62 |
On the road
Fitting up the new right-side rocker
04-25-2021, 12:12 PM | #63 |
On the road
Test fitting the door and here you can see the cab corner repair. I didn’t take pictures on this side but, I also installed a new partial inner rocker, kick panel patch and also replaced both the lower A and B pillars
04-25-2021, 12:14 PM | #64 |
On the road
Starting to fit up the left side. You can’t beat OEM rockers, they fit like a glove.
04-25-2021, 12:18 PM | #65 |
On the road
Cut out the inner rocker, both lower A and B pillars and the rusty section of the kick panel. I like to the cut the inner rockers in half and fit the front and rear separately, I sometimes find the length a little off. Also replaced the cab corner
04-25-2021, 12:20 PM | #66 |
On the road
A couple more shots
04-25-2021, 12:21 PM | #67 |
On the road
FOR SALE genuine GM patch panels, some assembly required.
04-25-2021, 12:25 PM | #68 |
On the road
The driver’s side is done.
04-25-2021, 12:28 PM | #69 |
On the road
Door bottoms are so much fun
04-25-2021, 12:32 PM | #70 |
On the road
Consolidated my parts onto the frame so I would have a bit more room to work but the cab will come back off to finish the bottom. It looks cool and at this point I needed a little motivation
04-25-2021, 12:36 PM | #71 |
On the road
Started on the Passenger door
04-25-2021, 12:39 PM | #72 |
On the road
Test fit the doors and fenders to be sure I didn't screw it up and to check alignment.
04-25-2021, 12:47 PM | #73 |
On the road
3 partial cab braces installed, one was still good. I cut out the floor board for a high hump, went with a repop high hump which works fine. This was to give me a little more room to shim the trans upward to better align the driveshaft. I dressed all the welds underneath and scrubbed, scraped and wire wheeled for hours but finally got the bottom of the cab cleaned up and coated with Ospho. I installed the high hump temporarily, so I could weld the nuts to the floor pan.
04-25-2021, 12:50 PM | #74 |
On the road
Masked it up and undercoated it so now I'm done underneath
04-25-2021, 09:45 PM | #75 |
It appears that the aftermarket panels do not have the drain slots built into the bottom. There must be a way for water to get out of the door. The reason the doors rust out is that the factory holes (slots) get clogged allowing dirt and water to pool in the bottom of the door. At least drill as couple of holes in the bottom of each door.
