Old 04-25-2021, 03:45 PM   #1
truckdude239
truckdude239's Avatar
tire size
so i had 255-70r15 tires on my 71 c10 long bed stock suspenion, it has 15x10 crome ralleys the tire shop apperantly could not get 255 70 15s to seat, as the wheels where 2 wide so they put 255/65r15 on it i hate that they dont really fill the wheel wells up and they ride hard as a brick i was thinking about a 265/70r15 or 275/60R15 what are yal running?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-25-2021, 06:05 PM   #2
weq92f
weq92f's Avatar
Re: tire size
I'm no tire wiz but seems they didn't really do the right thing for you. Wouldn't a 265/70/15 have been a better attempt? I used to run 275/??/15 on my stock 68.
Maybe what they put on was all they had in stock?
EDIT: I'm currently look at tires as well and can tell you I wish I was buying 15s: 4 choices on tirerack between 488 and 540 shipped.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-25-2021, 06:18 PM   #3
jayoldschool
Moderator
Re: tire size
Ether or a tire bead blaster will seat those tires real fast.
jayoldschool is online now   Reply With Quote
Old 04-26-2021, 08:59 AM   #4
cj847
cj847's Avatar
Re: tire size
I would go to a different tire store next time. Both tires are 255 so it should make little difference in seating. But, in any case 10" is way to wide for a 255 tire. You need a wider tire or a narrower rim.
If you want to keep your rims, see if you can fit a 275 or 285/60/15.
cj847 is offline   Reply With Quote
Old 04-26-2021, 02:14 PM   #5
Custom 68
Custom 68's Avatar
Re: tire size
You have probably already done the math but the 255-70 has a 1/2 inch sidewall difference so the overall height is 29 inches vs 28 inches.
When I was running 15 inch wheels I ran a couple different sizes. I did run a 275-60 15. That one had plenty of width and sidewall. It fit my truck well on the front and rear. That is the last ones I ran and would probably do that again based on 15 inch wheel.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-26-2021, 08:17 PM   #6
Mike C
Mike C's Avatar
Re: tire size
Change your wheels to some 8's. One of the biggest mistakes people make IMO with the stance/look of these trucks is 15x10 wheels in the front. They just stick out too far. The taller tire of the 70 series and the narrower 8" rim will make your truck look better IMO.
But 17's the best mod I've done on my truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
