Old 04-26-2021, 01:34 AM   #1
AllGoNoShow
Slight bend in frame...
I have a minor bend in the lower part of the c-channel of the frame in a small 4-6 inch section on my 1968. I’m guessing someone started jacking it without solidly being under it at some point in its life (picture below, although I am not sure why it is rotated upside down).
I can’t imagine it’s an issue but for purely aesthetic reasons as I’m going to be painting the frame soon, any ideas on how to straighten it back out? I was thinking of heating it with a torch, but not sure if that’s a good idea. Also thought about just clamping a piece of heavy square or rectangular tubing on either side and drawing it together to straighten it back out. What do you think?
AllGoNoShow is offline   Reply With Quote
Old 04-26-2021, 02:00 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Slight bend in frame...
Large crescent wrench , Slide it on , Adjust it tight and bend it back .
Old 04-26-2021, 02:32 AM   #3
Richard
Flipped for you. Was going to suggest the same as Grumpy. If you do not have one get the largest adjustable wrench available from Harbor Freight and bend it to where you want. Use a piece of pipe on the handle for more leverage if necessary. I would not use heat.
Richard
Old 04-27-2021, 12:17 AM   #4
Sheepdip
Sheepdip's Avatar
Grumpy's got the answer....may need a piece of pipe that will slip over the handle for a cheater, don't get in a hurry start outward and work it inward towards the center.
Just massage it in sections a little here a little there and you see great results.
Sheepdip is offline   Reply With Quote
Old 04-27-2021, 06:42 AM   #5
BigBird05
x4 on the crescent wrench
BigBird05 is offline   Reply With Quote
Old 04-27-2021, 08:11 AM   #6
sick472
sick472's Avatar
A Crescent wrench should work very well. Start towards the front (or back) and work it a little at a time, switching front to back as you move it a bit each time, working closer to the worst of the bend as you go. Keep doing this until it's straight. If you start at the worst part with a hefty bend, it WILL go back, but this bend will STRETCH the metal too much on either side of the initial bend. This will leave you with a wavy repair. Not real critical, but you can get a better result with some patience and just working it back a little at a time and moving from front to back as you dial it in.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 04-28-2021, 07:09 AM   #7
bigmac73
bigmac73's Avatar
i would not waste the time and energy. No one is going to see it or care
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 04-28-2021, 07:27 AM   #8
BigBird05
You should cut 2 blocks of wood to fit into the frame rails on either side of the bend. Clamp them in place. Then when you are bending the frame you are only bending in the bent area and not flexing the whole frame rail.
Old 04-28-2021, 01:06 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
My thoughts exactly.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-28-2021, 07:28 PM   #10
Carl Spangler
Carl Spangler's Avatar
^^^^^^^ Excellent suggestion!
1971 SWB step side: Original NM Forestry truck, then NM Fire truck, and now a ranch truck.
Carl Spangler is offline   Reply With Quote
Old 04-29-2021, 06:13 AM   #11
AllGoNoShow
I’ll give the crescent wrench a try. Thanks!
Old 04-29-2021, 04:58 PM   #12
68 TT
Still plays with trucks
68 TT's Avatar
When you do that put a second wrench on the adjacent area and use it to keep that straight section of frame from bending down while you are pulling on the dent. You could end up putting more bend into a larger area rather than removing the small bend if you don't keep the other area stationary.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 04-29-2021, 11:55 PM   #13
treveiger
treveiger's Avatar
If you know someone with a porta power that might work. You'd need a spacer though I'd think. Make sure when you bend it back to do so slowly and little bits at a time. Better to massage the metal back into place then to stretch it.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
