04-26-2021, 09:29 AM | #1 |
Wiper motor wiring
Finishing the under dash stuff, found my original wiper switch has only one terminal, the motor has 2....switch has 2 positions as per a two speed...checked continuity one original harness, yes one wire from switch to motor, will check other wire on motor for termination...not understanding how GM made this work...surely the switch isn’t a grounding point. Any thoughts???
04-26-2021, 10:12 AM | #2 |
Moderator
Re: Wiper motor wiring
You should have a yellow wire from the fuse panel to the motor. A light blue wire from the motor to the switch. The motor grounds thru the switch, so make sure grounds...
04-26-2021, 11:28 AM | #3 |
I've been using this http://67-72chevytrucks.com/vboard/s...19&postcount=4 and the American Autowire diagram https://www.americanautowire.com/med...20IN%200.0.pdf
04-26-2021, 04:27 PM | #4 | |
I had luckily kept the old harness and panel to check items like this, thanks for the help tho...... |
04-26-2021, 04:30 PM | #5 | |
04-26-2021, 05:10 PM | #6 |
The reason that it uses a ground is when you turn the switch off there still has to be power to the motor so it can park With the 2 speed switch and motor you basically have two grounds one ground to Low speed the other one for high-speed
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
04-27-2021, 07:08 AM | #7 | |
Moderator
When the wiper switch is turned on, it completes the circuit to ground (the dash). - http://67-72chevytrucks.com/vboard/s...d.php?t=413551
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 04-27-2021 at 07:14 AM. |
