04-28-2021, 06:55 PM | #1 |
69 -72 blazer doors
anyone know if i can use C10 doors and just cut the window frame out to use on a 72 blazer?
04-28-2021, 08:15 PM | #2 |
Re: 69 -72 blazer doors
Yes. The Factory Assembly Manual shows how to cut a truck door for Blazer applications. You'll need to find that little trim cap to cover the cut edges, and if you are being picky... You'll want a '72 truck door so that that the window crank / door handle shafts are long enough to fit the 72 door panel. In a perfect world, you'd also steal the reinforcement plates from the striker areas of "real" Blazer doors and spot weld them onto your new truck doors.
-G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
04-28-2021, 08:17 PM | #3 |
Yes, the assembly manual shows how to do it but the blazer doors have an extra reinforcement around the door latch which you can remove if you have some original blazer doors. Don't forget the stainless steel plate on the door also if you have original blazer doors, top inside corner contacts the bronze plate on the body.
04-28-2021, 08:19 PM | #4 |
LOL, guess we were typing at the same time.
04-28-2021, 08:20 PM | #5 |
I rarely know the correct answers to questions...so I get excited when I see something that I can actually answer. LOL
-G
04-29-2021, 06:14 PM | #6 |
Yes, Big J did a very good write up on it
http://67-72chevytrucks.com/vboard/s...d.php?t=273729
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
04-23-2022, 10:31 PM | #7 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by DeadheadNM; 04-23-2022 at 10:49 PM. Reason: Wtb |
