Old 07-14-2004, 09:59 AM   #1
hotrodhomi
hotrodhomi's Avatar
what is this?
What does this thing do and do I need it on my Californian truck? I’m installing a new set of Edelbrock smog legal headers. Truck is a ’81 and Im in process of swapping out the 305 for a 350.
hotrodhomi is offline   Reply With Quote
Old 07-14-2004, 10:12 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
That is the valve/flapper which causes the exhaust from the passenger side of the engine to flow through the intake exhaust-crossover to warm up the intake manifold faster. I do not know if it is required for emisions, but it plays an important role in allowing the engine to warm up quicker alowwing less emissions so I would quess it is required.
NeCrOmAnCeR is offline   Reply With Quote
Old 07-14-2004, 10:26 AM   #3
Grim Reaper
Well I would call your Nazi's and check.
If your truck has electric choke it's proably not going to make a huge difference with it gone in temps above 40degrees. Here in GA they don't care about stuff like that. Hell they most of the time don't even lift the hood. All the verify is that all exhaust appears to go through a Cat and do an anal probe sniffer test. Cali...all bets are off.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 07-14-2004, 11:52 AM   #4
SanitysBane
it also depends on which county your in, when he lived in houston they did the probe, now that we moved north of beumont to silsbee, they don't care at all. does it have 4 wheels and stop? good enough to them.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 07-14-2004, 12:05 PM   #5
Time Travel
Welcome to California. Yes you will need it. If the politicians have anything to say anyone with a 76 and up will always need it.
Time Travel is offline   Reply With Quote
Old 07-14-2004, 01:26 PM   #6
hotrodhomi
hotrodhomi's Avatar
so does that black hose hook to a vacuum line? Is that the only connection? The lkinkage looks all rusted up. Should I replace it?
Old 07-14-2004, 01:53 PM   #7
ChevyTech
The proper name for the part is EFE valve. (EARLY FUEL EVAPORATION)
They are sometime called a heat riser. That was the name used on older vehicals for the spring style units.
The vacuum hose should connect to a thermovacuum valve that is usually on the thermostat housing. The other port of the thrmo valve should be connected to vacuum. No other connections.
Apply vacuum to it and see if it moves and holds vacuum. Also, the hole in the end of the actuator arm get worn and loose. They can rattle loud as they are moving from the closed to the open postion, if they are worn.
Old 07-14-2004, 03:09 PM   #8
TIMSPEED
TIMSPEED's Avatar
Yes, you need that here in CA. It needs to hook up to a canister, then the canister hooks up to full vacuum on the carb, then the other side hooks up to the Temp Control Valve on the Air Intake tube. It's all part of the THERMAC system. (Air Intake, Heat Choke Stove Tube, Heat Riser valve)
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 07-16-2004, 12:44 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
I agree the Smog-Nazis will want you to have this fine piece of memorabilia. It is a real dinosaur from the past. The new cars are better at smog and most of them don't have to use this.
Old 07-16-2004, 09:12 PM   #10
plumbcut
california fill
just smogged my cali '77 sbc400 truck today. passed!
plumbcut is offline   Reply With Quote
