Routing Ididit Column Wiring
For those of you using an Ididit column, how did you route the wiring? It exits out of the bottom of the shift collar and I’m having a hard time routing it in a way that you don’t see it. I'm considering making a cover, but before I do that work, I wanted to see if others have routed theirs differently.
Moderator
![]() ![]() Join Date: Aug 2011
Re: Routing Ididit Column Wiring
I used something like this: https://kwikwire.com/products/techfl...ng-flat-sleeve
It's Better With Nitro
I run an Ididit Retro column and I just routed the harness to the left side of the column, then up and over the column dash bracket mount.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#4 | |
