05-07-2021, 10:02 AM | #1 |
express windows /modules
Adding relays to speed up the windows and then going one step further to add express up/down is a great mod, to me.
I know there are multiple threads on this subject and Gmachinz seemed to have the goods with his harnesses and modules. I know a few members had issues with him and he has since been banned from the forum. My question is, has anyone attempted to do the express up/down setup on their own? Did anyone purchase his harness w/ express up/down? Lastly, has anyone identified the express modules he used? (pic attached) He called them "solid state modules" but I cannot seem to find this item on line. I'm aware of the autoloc setup but I've heard/read mixed reviews. thanks in advance |
05-10-2021, 10:36 PM | #2 |
Re: express windows /modules
I have the kit from Gmachinz. I searched the part number for the relay / down module and it was for a 1997 Buick. I may still have the part number somewhere. I just bought another kit from him for a friend’s Blazer and it looks like a different part that he is using now. I bought the first kit from him years ago.
05-17-2021, 01:51 AM | #3 |
I got the LMC relay kit and it works OK - not as fast as a new truck but much faster than what I had. . I am not in a big enough hurry to go the express down route. I did get a replacement switch harness from LMC and it was not very good (arced out and blew the fusible link) but I did get it to work eventually and wrapped it up with electrical tape.
05-19-2021, 08:14 AM | #4 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-20-2021, 12:31 AM | #5 |
You could try the GM's 2008 up 2017 with express up/down option, Cruze, SILVERADO, CAMARO,MALIBU,TAHOE,EQUINOX, you will have to look at ones with high options and more... .
your mostly going to need two if you have a reg. Truck or four if you have a SUBURBAN style. You could go with aftermarket one I think they are re-tag GM or other big company re-tagged.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
05-22-2021, 01:57 AM | #6 |
My original kit I got from him in 2013 has this one from a 1996-1999 Buick or Oldsmobile. GM #25614182. https://www.ebay.com/itm/32457891740...SABEgKCRPD_BwE
05-22-2021, 09:41 AM | #7 |
Found some instructions where someone did it for an El Camino.
https://www.elcaminocentral.com/thre...h-video.61841/ |
