Question Axle/Wheel Seal 14B ff
Hey guys, I just got new axle/wheel seals (Timken 2081)
https://www.amazon.com/Timken-2081-S...omotive&sr=1-1 There is a flat side and the other side has a slight bevel at the inner diameter near the rubber seal. My question is: Is there an inside and outside to these. There's no markings to indicate such but the rubber seems to be angled or biased to one side (the side with the slight bevel) and I'm not certain if that goes in toward the differential or not. I believe that when I press it in, I should be looking at the flat side of the seal. Would that be correct? Thanks |
Re: Question Axle/Wheel Seal 14B ff
You are correct.
![]() Join Date: Dec 2009
I second that Yes
![]() Here is a side cutaway of a seal. The lip that has the spring above it is to seal the oil from escaping (Hopefully) ![]() The other lip is the Dust (Brake dust ) seal. Hope this helps. .
#4 | |
Thank you guys for the responses. I almost got it right. Installed the seal the correct direction and lubed bearing with 90 wt. Sure hope that works.
I worked on service trucks,
Years ago that had 14bolt FF. The Company was so cheap. I would jack the truck up /So much to tilt the rear-axle. Wait till the oil flowed to the bearings ![]() Then jack the other side up just to save money on the Grease ![]() This is why I remember that #2081 .
#7 | |
I wasn't trying to be cheap, just had the seal out, had to wait a week to get a new one (Had to order it) My truck is my only means of gettin 'round. Had no grease on hand. However, I did have some 90 wt. |
All about them K’s
![]() Join Date: Jun 2014
Use the updated seals from the 2001+ trucks next time. You’ll need one for say 2006 Silverado HD with a 6.0, that should still have the 10.5” 14 bolt ff. They are a two piece seal and are a direct swap to the old style. I use them every time I get into 14 bolt hubs and have never had a leak since.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#9 | |
#10 | |
Its a Truck Thing......
https://www.yukongear.com/productdet...x?ProdID=28421 The 30917 number is what I found in Rockauto. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#11 | |
All about them K’s
Yep that’s the one, however I use the genuine gm seals, I’ve got a part number written down in the shop. Let me see if I can round it up today.
that would be a cool thing and much appreciated. Knowing there's a seal that works well and has been tested is a bookmark item. Thank you
All about them K’s
You bet, GM 15823962
Heres one place that has them online: https://www.drivetrainamerica.com/15...eel-2001-2010/ The pictures make it look like a 1 piece seal but it is not. It’s got it’s own build in wear sleeve of sorts that installs on the axle. With My 1998 K2500 I could never seem to keep a hub seal in the passenger side for anymore than about 20,000 miles before they would start seeping oil into the brakes. After 100,000 miles of this, I swapped to the new style seals after being aggravated and having tried everything I could think to get them to seal. Since swapping to the new style, I’m 50,000 miles in and no issues since. Like I said I use them every time I tear into a set of hubs now.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 05-09-2021 at 07:54 PM. |
