05-15-2021, 11:22 AM | #1 |
BlahBlahBlah
Blazer buckets vs truck buckets
I'm assuming the only difference is the blazer gets a back on the bucket and the truck has the foam sort of showing in the back. And the truck passenger gets the stationary mounts vs the flip and slide (or maybe they dont slide?) version on the blazer. My guess is the driver side seat mount is the same truck and blazer.
I'm only talking about the "sport" buckets not the utility buckets.
... Last edited by CG; 05-15-2021 at 11:31 AM. |
05-15-2021, 02:22 PM | #2 |
Re: Blazer buckets vs truck buckets
My '70 Blazer pass seat just flips foward.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
05-15-2021, 06:10 PM | #3 |
BlahBlahBlah
Ok thanks, I guess that was the only area I wasn't fairly positive.
05-16-2021, 11:23 AM | #4 |
The Truck Buddy Buckets are mounted on a frame that uses the same setup as the Bench seat, and both seats move as one.
I put Blazer buckets in my truck. The mounting brackets are different length on the drivers seat and the passenger seat flips forward with a pivot hinge on the front and a locking latch on the rear. I fabricated the frames under mine, and used the sliders off two old bench seats. The outside bracket on each seat is mounted in the factory holes, and I drill holes for the insides with an extra reinforcement plate for safety. The only tricky problem I had was the adjustment lever on the passenger side is on the left side next to the console. I solved that issue by cutting the lever shorter and fanned a bracket and over mounted to the front leg. It works pretty good Last edited by custom10nut; 05-16-2021 at 12:20 PM. |
05-16-2021, 02:07 PM | #5 | |
BlahBlahBlah
But I do want to see if I understand you about the drivers seat sliders (not buddy seat). The seat itself is exactly the same for both, but you are saying the length of the actual sliders is different on a truck than a blazer. Ive never heard that before. I wonder if there is a thread somewhere that compares these?
05-16-2021, 02:19 PM | #6 |
The seats are the same. Truck/Suburbans got a stationary bracket on the passenger side and Blazer got the fold forward bracket.
I think something got lost in Custom Nuts reply. But I did like he did and fabricated sliding bucket brackets from two sets of bench seat brackets. There's a thread somewhere (not mine)
05-16-2021, 02:30 PM | #7 |
BlahBlahBlah
Ok thanks for that!
05-16-2021, 05:14 PM | #8 | |
05-16-2021, 05:33 PM | #9 |
BlahBlahBlah
Ok this is what Im thinking now ... The confusion seems to be (to me) that somehow converting bench seat sliders to bucket seat sliders was tossed in the equation.
I'm only talking about stock bucket seat sliders, not anything converted. So this is how I understand it ... For the stock version of the passenger buckets ... Trucks have the stationary brackets that dont do anything except hold the seat in place, blazers do the same except they flip forward to allow access to the rear seat. And now I believe that the stock truck drivers side bucket is exactly the same as a stock blazer drivers side bucket in every way except the blazer buckets have the plastic back. Whew!
05-16-2021, 10:02 PM | #10 | |
Later this summer Im going to be tearing my truck apart to finally get it into a finished state, and I will take pictures along the way, to include a few of the seat frames, I promise. Im finally getting my Dream Shop put up this summer, and the first priority is the truck. |
05-17-2021, 10:51 PM | #11 |
Blazer and Truck Sport buckets are the same CG.
Driver side sliders same. Passenger side Not. Blazers got plastic backs. Trucks nothing. 69-72 all same frames and below just for fun. 73-77 Same frames as 69-72, just side skirts taper towards back of seat up an inch and a half vs 3 inch straight skirts 69-72. |
04-10-2024, 10:21 AM | #12 |
I know this is an old thread, but I am going to use modified bench brackets as well and would like a pic of the adjustment lever mod you did. Could you post a pic of your lever?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
04-11-2024, 12:39 AM | #13 |
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
