Old 05-16-2021, 11:33 PM   #51
hardwaa
hardwaa's Avatar
I’m not trying to go super low with this truck just have essentially an old man hot rod hauler that I can use to run around and pick up parts and just have fun.
hardwaa is offline   Reply With Quote
Old 05-16-2021, 11:34 PM   #52
hardwaa
hardwaa's Avatar
Here it is off the Jack. This old cowboy truck is a little less country and a little more rock ‘n’ roll. Can’t wait to get the rear done.
Old 05-17-2021, 11:02 AM   #53
68Gold/white
Re: My 1968 C-20 vermillion metallic...1 in a VERmillion
Look'n good in the Arizona neighborhood!!!
Amazing how the wheels and trim make it look sooo much better!!!
Carry on! THat's how I would do it!!!
68Gold/white is offline   Reply With Quote
Old 05-18-2021, 07:05 PM   #54
Low Elco
Oooooo...dis gon' be goooodd.....
Low Elco is offline   Reply With Quote
Old 05-20-2021, 11:00 PM   #55
hardwaa
hardwaa's Avatar
Old 05-20-2021, 11:04 PM   #56
hardwaa
hardwaa's Avatar
1/2 ton rear end. Gonna swap to 5 lug axles. ? On ring gear pic 11:41 assuming that’s teeth on pinion and ring gear. 3.73 ratio. Is that a date code on righ gear “GM 2-68” ????
Old 05-20-2021, 11:43 PM   #57
68Gold/white
Correct on the ratio numbers. I don’t know for sure on date code, it’s likely a 68 rear.
I’m sure I’m captain obvious, here, but make sure you get the correct length axles for the axle housing! If you get Moser axles, buy the studs AND have them install them, it’s worth every penny!
I plan on 3.73 gears for my 67 and 68. If you DO need new gears, I’ve read that Motive gear is preferred, for reasons I don’t remember...
Old 05-21-2021, 07:58 PM   #58
hardwaa
hardwaa's Avatar
My truck is a 3/4 ton this is a random 6 lug 1/2 ton rear I scored from a buddy. I’m happy with the 30 spline. Will look for best axles. 30 3/4 length.
Old 05-23-2021, 01:58 PM   #59
CG
BlahBlahBlah
Are you going the CLR treatment and buff and wax when done?
Old 05-25-2021, 11:37 PM   #60
hardwaa
hardwaa's Avatar
Not sure time will tell. I do like that look though.
Old 05-25-2021, 11:40 PM   #61
hardwaa
hardwaa's Avatar
Progress from Sunday. Rear end removal started.
Old 05-25-2021, 11:43 PM   #62
hardwaa
hardwaa's Avatar
Progress from today. Rear axle, rear 3/4ton springs, rear helper springs, rear bumper removed
Old 05-25-2021, 11:51 PM   #63
hardwaa
hardwaa's Avatar
Tie rods. 3/4 ton to 1/2 ton for 1/2 ton spindle. Just needed AZ Pro performance sleeves. I did not change 3/4 ton center link.
Old 05-27-2021, 02:01 PM   #64
rodstored-72
chevy truck fan
rodstored-72's Avatar
hardwaa, the truck's finish looks to be a good candidate for that. the overall finish is consistant & the "patina" seems to be in the right spots too. just my 0.02 worth though, I like a very nice paint job too!
one of these days we will need to meet over at each other's garage - I believe we are pretty close to each other....
rodstored-72 is offline   Reply With Quote
Old 05-30-2021, 01:27 PM   #65
hardwaa
hardwaa's Avatar
Progress !! No more 3/4 ton now 1/2 ton with 5 lug swap.
Old 05-30-2021, 10:32 PM   #66
hewittca
hewittca's Avatar
Old school cool!
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 06-02-2021, 01:11 AM   #67
hardwaa
hardwaa's Avatar
Plan is to test drive after I bleed brakes. Really digging this 1968 !!
Old 06-02-2021, 11:10 AM   #68
67C10Step
67C10Step's Avatar
Very nice and making progress! I think if you give that thing a good bath, a little CLR and maybe some polish here and there you will be getting waves and thumbs up all over town.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 06-03-2021, 01:08 AM   #69
68Gold/white
What size tires did you use?
Did you get the bench seat re- done?
Thanks for all you have shared. I’m sure there are other threads here that have converted a 3/4 ton to a half ton, but yours is first I’ve seen, Very well done!
Old 06-03-2021, 04:34 PM   #70
hardwaa
hardwaa's Avatar
Old 06-03-2021, 04:35 PM   #71
hardwaa
hardwaa's Avatar
We got a driver. Time to start putting some miles on it and getting it all cleaned up.
Old 06-03-2021, 05:06 PM   #72
Chevys4life
Man............that boy is looking good. I love the wheel and tire package along with the stance now. And it is a full bed and not any of that short stuff.
Chevys4life is offline   Reply With Quote
Old 06-03-2021, 05:44 PM   #73
68Gold/white
To quote the immortal Jethro Bodine...
"Yeee Haaaa"!!!
Old 06-07-2021, 06:28 PM   #74
Low Elco
Weeellllll doggies! Looks great!
Old 06-08-2021, 12:32 PM   #75
hardwaa
hardwaa's Avatar
Thanks guys!
Seat time. Here is the before pics. Dropping seat off today to get upholstered.
