Old 05-23-2021, 01:47 PM   #1
scottmitchellrose
back up light housing and socket
so one back up light is bad- think it's the connector etc. I was 'smart' Ughh) enough to take the housing out and cut the wire. Now I'm not sure about the connector- it's a brass housing with a 'pin' stuck to the end of the wire that the bulb seems to push in. Must have been a spring- gone.... is there a diagram of the 52 year old junk I cut out- what I need in so far as what goes into the middle of that brass housing so that I may attach the green (back up) wire to it?
scottmitchellrose is offline   Reply With Quote
Old 05-23-2021, 10:21 PM   #2
RustyPile
RustyPile's Avatar
Re: back up light housing and socket
If the housing is in good useable condition, you can get a single contact repair pigtail "kit" from any parts store and probably a million internet vendors.. The "kit" contains a wire pigtail with the proper contact terminal on the end of it.. Also in the kit is a spring and a insulator disk that keeps the terminal in the center of the socket...
Spoon feeding is not my forte but something like this... https://www.sherco-auto.com/4-single...r-pigtail.html
RustyPile is online now   Reply With Quote
Old 05-24-2021, 11:49 AM   #3
scottmitchellrose
aha! I knew there had to be a spring in there! That was spoon feeding- and you were good at it! I appreciate it,
Scott
