05-24-2021, 02:23 PM | #1 |
Suburban lowering question
Will the lowering kits for 84-87 fit on the 89? If so, what kit do you use? If not, what kit do you use? TIA
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-24-2021, 03:46 PM | #2 |
Re: Suburban lowering question
Kits for 73-88 or what ever the change over is will work.
Being a Burb you should 1.25 inch rotors. I would do spindles before coils depending on how low you desire to go. |
05-24-2021, 07:55 PM | #3 |
67-72 parts collector,…
89-81 suburbans are the same as the 73-87 burbs.
Also mentioned you should have the 1.25” rotors. I had a 91 burb lowered with 4” drop leaf springs. You will need to shim the carrier bearing mount to help with driveshaft length. I had drop spindles and springs up front. I see a lot of people using flip kits on the rear. TinWorks Fabrication make a bolt in c-notch with the “suburban only” body mount built in. This gets you axle clearance, but also gets the center section of the rearend close to the bed floor. Good luck with your build.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-25-2021 at 05:25 PM. |
05-25-2021, 08:24 AM | #4 | ||
05-25-2021, 12:05 PM | #5 |
Lower it just a couple of inches with spindles and shackles, it wide ride the same and look nice with your wheel and tire combination.
05-25-2021, 12:15 PM | #6 |
I told you wrong.
These were 4” drop leaf springs.
05-25-2021, 01:07 PM | #7 | |
Whose kit did you use?
05-25-2021, 05:24 PM | #8 |
No kit.
They were Chisholm Leaf Springs, (out of business now) I would use Western Chassis if you want drop leaf springs. I thought a flip kit would be too low and no one made a bolt-in c-notch back then. Belltech 3” drop spindles and 2” drop springs. Belltech nitro drop shocks with rear shock extenders. 15x7 and 15x8 rally wheels. 215/70-15 and 275/60-15 tires.
05-25-2021, 05:25 PM | #9 |
Standard C10 lowering stuff up front.
Tinworks c-notch & flip kit out back. Swap a lift shackle in place if the flip is too much.
05-25-2021, 05:55 PM | #10 |
Better plan,... ^^^
05-26-2021, 08:39 AM | #11 |
I purchased 4 inch drop leafs and 3 inch coils for my Burban from Western chassis. Sold the truck before I had a chance to install.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
05-26-2021, 01:27 PM | #12 | ||
Agreed! I'm guessing the parts went with the Burb?
05-26-2021, 03:44 PM | #13 |
Here's 4/6 drop, details are all in the build thread:
And the notch will get you axle clearance, but before the axle hits the frame or the diff hits the floor the tires will rub on the tops of the wheelhouses. That was NOT something I factored in...
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler Last edited by BlueJeep; 05-26-2021 at 03:49 PM. |
05-26-2021, 04:08 PM | #14 |
I used drop spindles and springs up front. In the back, I flipped the axle but then it was too low. In order to avoid notching the frame I lifted it back up a little with some short shackles from Rancho. That gave me enough clearance.
05-26-2021, 05:01 PM | #15 |
I thought I mentioned that clearance caveat & why I suggested raising the floor directly above the differential?
05-26-2021, 05:11 PM | #16 | |
Effectively, the tires rubbing on the wheel tubs are the "bump stops". I assume the wheel tubs are lower than the equivalent pickup ones, which is why the axle flipped truck guys don't mention this.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
05-26-2021, 06:31 PM | #17 | |
Thanks for the insight.
05-26-2021, 06:43 PM | #18 | |
Hopefully all of this is somewhat helpful to Hart Rod!
05-26-2021, 08:31 PM | #19 |
No I still have them . New owner was keeping it all original . I guess I can see his point truck had never been touched.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 05-26-2021 at 08:39 PM. |
05-26-2021, 09:49 PM | #20 | |
05-27-2021, 12:53 AM | #21 |
I recall he was using 295/45-20's @ ~30.4" tall in the rear.
05-27-2021, 07:46 AM | #22 |
05-27-2021, 11:00 AM | #23 |
Yep, they are what seems to be a "normal" size rear tire for squarebodies. 235/75R15 was stock and that is @28.9", so 1.5" taller, and .75" closer to the wheel tub.
Correct.
05-30-2021, 12:54 PM | #24 |
Are you interested in selling those parts? LMK.
05-30-2021, 01:32 PM | #25 |
I have been looking for a square to use them on . I did speak with St.Louis about the leaf spring and the guy told me they fit my 72 C20 I'm not so sure though
I think shipping would be way more than they are worth.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 06-07-2021 at 06:31 PM. |
