Old 05-26-2021, 01:59 PM   #1
AK56
AK56's Avatar
Hood emblem gasket 56??
Im getting ready to bolt on my hood emblem. I have searched everywhere and cant find a gasket for a 56 emblem. Did they not use gaskets after 55??
Really having a hard time bolting it directly to my new paint. If nothing else I will use some 3M clear tape but would rather use a gasket. Any insight would be appreciated!
AK56 is offline   Reply With Quote
Old 05-26-2021, 03:12 PM   #2
dsraven
Re: Hood emblem gasket 56??
my 57 came sans emblem. I would check with an autobody supply shop and see if they have some thin gasket material, something that is a closed cell foam would be good because it doesn't sponge water. possibly some emblem tape? possibly some thin foam like used under a wall in a basement? possibly a thin cork sheet from a hobby shop or a cheap bulletin board? thn rubber sheet from a plumbing store or plastic supply outfit? some thin eva foam?
Old 05-26-2021, 10:19 PM   #3
AK56
AK56's Avatar
That’s probably the route I will have to go. Build my own. Thanks for the suggestions!
Old 05-27-2021, 03:30 PM   #4
57tailgater
Looks like in the factory assembly manual there was none for the '55. Not sure for a '56 to '57. I don't recall one on my '57.
57tailgater is offline   Reply With Quote
Old 05-27-2021, 05:08 PM   #5
MiraclePieCo
MiraclePieCo's Avatar
Even though my AD hood emblem came with a gasket, I chose not to use it. My reasoning was that it would trap moisture that could eventually produce rust.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 05-27-2021, 08:23 PM   #6
_Ogre
_Ogre's Avatar
i can't say i've ever seen a gasket on any trim
shop air compressor timer
Old 05-28-2021, 11:37 AM   #7
1project2many
I believe I used nylon washers behind the emblem to help keep pressure off the paint. No gasket.
1project2many is offline   Reply With Quote
