Old 05-26-2021, 08:04 PM   #1
dooguy
adapting np 208 to 72 k20
any info on adapting the transfer case floor shift to a 1972 k20. it is different than the np 205 type
dooguy is offline   Reply With Quote
Old 05-26-2021, 09:03 PM   #2
52napco
Re: adapting np 208 to 72 k20
Completely different animal if you have a 205 case is not happening...
52napco is offline   Reply With Quote
Old 05-27-2021, 12:18 AM   #3
dooguy
are you saying the np208 wont work in this model pickup? I may not have described correctly. the 205 was changed out for a 208 and now I want to adapt the transfer case floor shift and linkage to work with a 208
Old 05-27-2021, 01:27 AM   #4
franken
If the 208 is already in the truck chances are the trans was swapped as well. The 208 uses a different shifter that bolts to the floor. The 205 shifter bolts to the trans to TC adapter that's most likely gone. You might be able to fab a bracket to mount the 205 shift lever.
https://www.google.com/search?q=np20...&bih=900&dpr=1
https://www.google.com/search?q=np20...tkm9vDadS913tM
Old 05-28-2021, 06:46 AM   #5
52napco
Is your truck a k vin 4wd or a later frame..post some pics..I don't think it's reasonable to utilize the 205 shifter...
Old 05-28-2021, 01:33 PM   #6
dooguy
my donor frame is a K vin.
