Old 06-03-2021, 05:14 AM   #1
Harold Holbrook
Seat Belt Restoration
Does any one know of a good seat belt restoration shop?
Harold Holbrook is offline   Reply With Quote
Old 06-03-2021, 10:33 AM   #2
hemi43
hemi43's Avatar
Re: Seat Belt Restoration
What's wrong with yours? If its just discoloration, you can paint them. I've done this many times with amazing results using SEM or Color Bond dye.
hemi43 is offline   Reply With Quote
Old 06-03-2021, 02:01 PM   #3
Harold Holbrook
I want the webbing to be change. Parchment
Old 06-03-2021, 07:51 PM   #4
Blazerowner
Blazerowner's Avatar
The place below is supposed to be top quality but plan to pay a lot.
https://www.ssnake-oyl.com/mm5/merch...tegory_Code=RS
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 06-04-2021, 01:52 PM   #5
Harold Holbrook
Thanks, All
Old 06-25-2021, 05:37 PM   #6
YellowK5
Active Member
Try Seat Belt Planet..they do a lot of work for us at our shop
Scott
My first post yea!
YellowK5 is offline   Reply With Quote
Old 06-25-2021, 07:18 PM   #7
Harold Holbrook
Old 06-27-2021, 07:16 PM   #8
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Mine are going to Snake Oyl
Tom Vogel is offline   Reply With Quote
Old 06-29-2021, 09:31 AM   #9
best view
I thought a member on here does them maybe they’ll chime in
best view is offline   Reply With Quote
Old 06-29-2021, 11:36 AM   #10
Maineviking
I just had a parchment set done by Snakeoyl. All I can say is wow.
Maineviking is offline   Reply With Quote
Old 06-29-2021, 01:43 PM   #11
Harold Holbrook
I just sent my parchment seat belts to Ssnake Oyl. I am missing the 4 boot covers that goes behind the back seat. Any color any amount would be appreciated.
Old 06-29-2021, 10:20 PM   #12
70cst
70cst's Avatar
Scott
My first post yea!
And it ws a good post
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-02-2021, 06:10 PM   #13
YellowK5
Active Member
Excellent! Steve (our rep)is a good guy and takes great care of us
Old 07-03-2021, 06:17 PM   #14
72ironmike
72ironmike's Avatar
I found pythonrestoration - they polish the buckle covers instead of paint them
I have used ssnakeoyl in the past & was unhappy with color match
Will let all know how they turn out after a couple month turnaround
Here's some examples
Anyone know what the plastic boot is on the one seatbelt circled in yellow ?
Only one of my belts has this & I do not know where I took it off at !
72ironmike is online now   Reply With Quote
Old 07-03-2021, 07:43 PM   #15
1rippen6
It's the passenger side blazer belt, I would say that's the hardest belt to find!! It goes with the small retractor, next hardest to find.
1rippen6 is offline   Reply With Quote
Old 07-05-2021, 10:48 AM   #16
Harold Holbrook
I had that on one of mine. Ask Ssnake- Oyl to install it on the other side. I thought it was to keep the belt from sliding down between the seat and the consul.
Old 07-06-2021, 10:23 AM   #17
72ironmike
72ironmike's Avatar
Harold, I lucked out and found my belt boots. If you do not find any you might look for some longer ones & cut them down. That is what pythonrestoration.com suggested I might do. I kinda like the look that they will actually cover the bolt head. Good luck. Thank goodness Blazer/Jimmies are worth so much because they are PITA !
Old 07-06-2021, 08:30 PM   #18
Harold Holbrook
Thanks, Mike I was thinking of doing that and found a original set.
Old 07-07-2021, 07:14 AM   #19
72ironmike
72ironmike's Avatar
Like a needle in a haystack !
Here's a pic of my original cores "before" !
Old 07-07-2021, 12:14 PM   #20
Harold Holbrook
Thanks Mike for the pictures.
Old 09-08-2021, 09:10 PM   #21
72ironmike
72ironmike's Avatar
Here is the after !
Old 09-09-2021, 10:41 AM   #22
Blazerowner
Here is the after !
Any chance you can share the price for the work?
Kirk
Old 09-09-2021, 01:53 PM   #23
lks dcvn
lks dcvn's Avatar
^ same question (about cost of the work) as I will probably need to do the same with a set of parchment belts for my blazer project...
lks dcvn is offline   Reply With Quote
Old 09-09-2021, 01:54 PM   #24
SeventyOne
I used Python a couple years ago as well on my parchment belts. excellent job just took a while.
SeventyOne is offline   Reply With Quote
Old 09-09-2021, 10:57 PM   #25
72ironmike
72ironmike's Avatar
$607 Took about 8 weeks.
Fronts are 105 each
Rears 80
Date code tags 10 each if you want them
That is with good core belts
