Old 06-07-2021, 02:10 PM   #1
brian1115
help with steering column
I have a 86 c10 that didn't come factory with delay wipers. I swapped in a new unit but I have a question when putting back the top cover of the steering column. Are the gears in the correct position when putting it back together?
1986 Chevy Fleetside Wrangler (Canadian Only)
brian1115 is offline   Reply With Quote
Old 06-26-2021, 12:56 PM   #2
90K5
90K5's Avatar
Re: help with steering column
When you mesh the "round gear" pinion with the "flat gear" rack, the wide tooth on the pinion should be meshed with the wide opening on the rack. That will assure that the timing is correct and you can then adjust the electrical switch correctly.
Hope that's clear as mud!!
What God has put together, let no man put asunder... Matt 19:6
90K5 is offline   Reply With Quote
Old 06-27-2021, 09:30 AM   #3
brian1115
Thanks I got it sorted!
