Headlights, dash lights & front side markers not working
All three just stopped working. After they stopped working I did a ground up rebuild on the front end and installed a new front wiring harness so I know it’s not up there, I also put in a new headlight switch, didn’t fix the problem either, checked the wiring plug to the switch and it has power.
Is this a ground problem? The parking and tail lights are part of the switch and they work. Any insight would be greatly appreciated. |
#2 | |
Re: Headlights, dash lights & front side markers not working
![]() Join Date: Aug 2019
If the park and tail lights are working it isn't a ground problem.
![]() ![]() Join Date: Sep 2008
It's your headlight dimmer switch.
If you have power to the head light switch ( big red wire ) then it is the head light switch that has gone bad.
Side markers probably need ground. Do they have power to them?
