#151 | |
Re: Hard Starting Hot
#152 | |
Mr. Cheyenne
![]() Join Date: Jun 2020
I put the throttle half way and I can move the throttle side to side. Not sure if that is what you mean but I can move it laterally. When I pull the throttle out from the body, I can get almost a penny wedged in. Yes, she was full warmed up real good. What do you mean by QC ... to me that means quality control.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#153 | |
Quadrajet parts sells a special stepped drill and the bushings: https://quadrajetparts.com/carbureto...uad-p-886.html Available in 3/8" and 5/16" This is the tool I used to fix my worn out carb.
1971 SWB step side: Original NM Forestry truck, then NM Fire truck, and now a ranch truck. Last edited by Carl Spangler; 05-23-2021 at 04:17 PM. |
#154 |
Mr. Cheyenne
Yes, I have seen that kit (that is where I got my standard rebuild kit for my original carb). I suppose I had it in my mind that QuadraJet Power would do this - I see this in their YouTube. Not sure how to "spy" for the bushings.
https://www.youtube.com/watch?v=Nz46xrO_I-o I have the carb off the truck again, so no spring is attached but I did pour gas all over me (which pissed off everyone in the house and I was made to take a bath and change LOL).
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 05-23-2021 at 04:41 PM. |
#155 |
Mr. Cheyenne
#156 |
hmmmmmmm................ that's more longitudinal play than I'm used to seeing. I'm not sure if that's a show-stopper. ???
Since this carb was rebuilt by the folks that make the shaft bushings/tool it would seem unlikely that the bushings weren't properly installed. ??? Again, if the shaft bushings are new there should be virtually zero clearance between the shaft and bushing.
1971 SWB step side: Original NM Forestry truck, then NM Fire truck, and now a ranch truck. |
#157 |
Mr. Cheyenne
while holding the throttle good and closed (so it isn't moving longitudinally), it does wiggle.
#158 | |
#159 |
Mr. Cheyenne
To be honest, it doesn't wiggle much at all but it does move.
Anyways, filled out the form to return the carb and its already on its way from the Kyle Post Office. Mark from QuadraJet Power did tell me this morning the bushing were installed - that was part of the rebuild process on my carb. Not sure what that means, if after installing these bushing there isn't suppose to be any movement. Though most definitely there wasn't anything done to stop any lateral movement.
#160 |
![]() Join Date: Feb 2016
Throttle shaft bushings on a new Qjet (NOS) will allow the shaft to wiggle. 002 to .004. As the carburetor goes through it's life the base plate holes will wear as will the throttle shaft. An extremely worn carburetor will have 3/16 of fore and aft play in the shaft.
The majority of the wear occurs in the base plate due to it being a softer material than the steel throttle shaft. The result being that when new bushings are installed there may be play than in a brand new carburetor due to the wear on the throttle shaft. This additional play would be measured in thousands of an inch not fractions of an inch. I speculate that you are feeling this amount of play and it should not be a problem. This small amount of play is allowing a small amount of air into the intake below the carburetor metering circuits. This type of air leakage was designed to be compensated by the idle mixture screws. Thus over the designed life span of vehicle proper idle characteristics could be maintained. Can you give us a measurement of the play you can feel? The average human can easlly detect .010 of play but, most don't know how to communicate that amount. I suggest you compare the amount of play you have to a feeler guage and let us know your findings.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#161 |
Mr. Cheyenne
The carb has already gone back to QuadraJet Power. Either they'll tell me I'm a idiot (very possible) or there is something wrong with the carb (I hope this option).
#162 |
I am suspicious that the carb may have issue in the main body or possibly a mismatch with the base plate.
What kind of shape was the carburetor in when you received it? I have seen lots of frankenjets over the years. Different year carburetor sections bolted together or a Chevrolet main body bolted to a Buick base plate. In almost every case this causes problems for the vehicle operation. Sometimes it is just some one trying to solve a problem other times it is an unscrupulous seller looking to sell an incomplete carburetor for more money. I do wonder too about your quote from QP: From Mark @QP Quote: Carb can idle with them closed. It has bypass air built in and we richened the mixture based on your engine descriptions. This essentially means they physically modified the idle circuit in the main body of the carb which is may not be problem but they did it before the carburetor was on the vehicle and driven. If I am not mistaken you have a basically stock engine with the correct carburetor on it. If that statement is correct then such a modification should not be necessary. I have modified the idle circuits on my Burban's Qjet but it is off of a 1978 400 cu engine. The idle circuits were designed for emissions and as a result too lean for my engine. By modifying the circuits we were able to get the idle mixture screws to work properly. Scroll to post 455 in the link below for more info on what was done. A common problem these days comes from corrosion. Most people seem to think that letting a carburetor sit out in the weather is not a problem. This is far from the truth. The metering circuits in the carburetor are machined to very exact specifications that are matched to the specific engine it is going to be installed on, whether or not it has to meet California emissions, and if it was going to be shipped to a high altitude dealership. When one of these precision machined passages become corroded they become larger and now will no longer meter correctly resulting in driveablity issues that are difficult if not impossible to solve. Folks who drag carburetors from swap meet to swap meet and let them sit in the rain time after time deserve a special place in he11. Photo below is a good example. Not a Qjet but a reasonable looking carburetor on the exterior but corroded badly on the inside to the point that rebuilding it may not be possible. Not something a person who spent $600 for a correct carburetor wants to hear. One other problem that comes to mind which is rare ( We've only seen it twice that we know of over the years) is you may have a crack in the main body that only causes problems when the carburetor is hot. This is a hard to troubleshoot problem that many people have never run across. Good luck and keep us posted. https://67-72chevytrucks.com/vboard/...698377&page=19
#163 | |
Mr. Cheyenne
The carb that I sent them, came to me looking from the outside very clean (I wasn't about to open it up, what would I know anyways if I did). It was actually a carb I got in a outfit from Chicago that sells rebuilt carbs. So I bought it for fairly good money and then didn't mind having it rebuilt again to have it perfect.
This is what they said about it when they got to it before the rebuild: Quote:
When I reached out to them, I told them about my engine being rebuilt to stock with a mild RV Cam. I asked about getting them to do my carb, I told them I really wanted them to be sure the secondaries kicked and were adjusted properly. They told me I needed their "level 2 performance build" for that adjustment. Even if I thought that was a bit odd for that one adjustment, I did not argue the point. I don't mind paying proper money for proper work, ever. If I can't pay for something, well then I don't get the work done. Not sure if I answered all your questions, I think I did. The carb showed up in their PO Box today... now more waiting I am sure.
#164 | ||
Mr. Cheyenne
Carb is on its way back!
Man, getting information from these guys is like pulling teeth - I really don’t get that. Even if everything is perfect, I won’t recommend them because of that. So after 3 requests for information (after I got a email it had shipped back) this is what I got. Quote:
#165 |
Who Changed This?
![]() Join Date: Jan 2013
I remember that Mark had a pretty good name with Q-Jets. Hopefully it runs well when you get it back, and was a one-off with the problems.
#166 |
The implied relationship between empty fuel lines and hard starting is odd. You're using fuel in the bowl for starting.
#167 |
Now that I think about it ............... I've never used that little clip on the float 'needle'. Things that make you go hmmmmmmm.
#168 |
Mr. Cheyenne
It’s mostly Greek to me.
#169 |
Mr. Cheyenne
Well, I know now what “remove clip on the needle/seat” means after some searching. Not really sure why they did that, since my current carb doesnt have a issue. My understanding is if you let your Vehicle sit to long the needle can get stuck and the only why to fix that is to take the carb apart.
Great, something to worry about.
#170 | |
Like I mentioned above I've never used that clip and I've been rebuilding carbs since the early 70's. Carbs today are a problematic due to the high volatility fuels we are saddled with. It is what it is.................. ![]()
#171 |
Mr. Cheyenne
Ah, thank you for that input <3
#172 |
Who Changed This?
I could see the needle sticking in the seat if the fuel was gummy and then the bowl dried out. But the bowl goes dry on my truck all the time, as I drive it maybe every few weeks. I have an electric fuel pump to feed the mechanical pump, so I run that for a bit, to avoid cranking too much.
#173 |
If you're still having issues and you suspect fuel delivery, or no fuel in bowl, or
you just want to eliminate fuel in the bowl before trying to start it. Heres a link to show how to check the float level with the vehicle running. This would insure the fuel level in the bowl is correct and you can use the same gauge to see if theres fuel in the bowl after the truck has set for a while. http://ww2.justanswer.com/uploads/ca...ajet_Dodge.pdf Heres where you can order the gauge https://www.summitracing.com/parts/smp-ct10 I used this style of gauge when I use to work on the computer controlled quadrajets. Hope this helps |
#174 |
#175 | |
Mr. Cheyenne
I got the returned carburetor installed this morning. I have to say, it's much easier to get her to run down the road without her falling flat on her face. I think I got her dial in okay, though on Tuesday I'll have my shop take a look (she is going in to relook at my rear end leak). The difference is night and day but it is apparent I am no carburetor tuner. This is even with my fancy timing light (to watch for max idle) and vacuum gauge (to watch for max vacuum)!
With that said, I still have these problems:
Seems the "whistling" would be a air leak, which in turn allows the engine to still idle, even though the throttle is fully closed. Edit: From Mark @QuadraJet Power Quote:
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 06-20-2021 at 10:17 AM. |
