06-13-2021, 10:04 PM | #1 |
69 Fuel Lines
I'm building a 69 GMC short wide bed truck with a 350 and sniper EFI.
Also I'm relocating the fuel tank to the frame in the rear. My question is what year model fuel lines to run from the front to rear? I would prefer to stay with OEM lines if possible. Thanks |
06-14-2021, 02:53 AM | #2 |
Re: 69 Fuel Lines
When I moved my tank to the rear I just made my own lines. Since your running fuel inj, your going to need a larger fuel line then stock plus a larger return line.
06-15-2021, 01:19 PM | #3 |
Re: 69 Fuel Lines
I was thinking more along the line of using pre-bent lines from a year model that had a rear tank and changing out the fittings.
Holley says in need a 3/8" line for both. Would 2 fuel lines (3/8") for a 72 model work? Thanks |
06-21-2021, 02:02 PM | #4 |
Re: 69 Fuel Lines
Bump
06-21-2021, 03:04 PM | #5 |
Re: 69 Fuel Lines
If you must use pre-bent lines. I would say your best bet it to call Inline Tube and see if they can offer any help.
For my LS Swap with Boyds tank. I made my own lines using 3/8 aluminum tubing from Summit: https://www.summitracing.com/parts/sum-g2538 Fairly inexpensive for the tubing, but the AN fittings and hoses, probably added another $100 The aluminum tubing is so much easier than even the Nickle Copper. With the aluminum you can basically manipulate it with no tools. I did use a bender for some areas where I wanted a 90. I used these clamps to attach the tubing inside the frame rail: https://www.summitracing.com/parts/nth-1616-6 I basically cut the 25ft roll in half and got both pieces fished into the frame rail. Started at the back where the tank is and put 2 clamps, then just worked my way to the front installing clamps in a uniform fashion. |
06-21-2021, 07:47 PM | #6 |
Re: 69 Fuel Lines
Thanks. Inline tube suggested the same thing- build your own.
06-21-2021, 08:08 PM | #7 | |
Re: 69 Fuel Lines
1989 5.0 LX Coupe 1989 Saleen #243 1969 C-10 Fleetside 1966 Mustang Coupe GT 1965 Fastback Mustang 1951 F1 Truck |
06-21-2021, 08:31 PM | #8 |
Re: 69 Fuel Lines
I used these to attach to the tubing:
https://www.summitracing.com/parts/sum-2200075b https://www.summitracing.com/parts/sum-2200077b Using the above will not require a 37° flaring tool, which is not common. I bought a flaring tool for some reason, thinking I was going to use the tube nut/sleeve combo like these: https://www.summitracing.com/parts/sum-220633-2b https://www.summitracing.com/parts/sum-220634-2b With the tube nut and sleeve, you put the nut then sleeve on the tube and flare the tubing and you can then connect to a male AN fitting. |
06-21-2021, 10:02 PM | #9 |
Re: 69 Fuel Lines
Thank You!!
06-21-2021, 10:04 PM | #10 | |
Re: 69 Fuel Lines
