#1251 | |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: What did you do to your Blazer/Jimmy today?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#1252 |
I posted pics, it happened!!
Or these? ![]() ![]() ![]() ![]()
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#1253 |
Carpe manana
Oops. The photos are blocked here at work. Sorry! I can see these on my phone - glad this buy went better than the last member buy. Enjoy, that's a great buy.
#1254 |
Nothing, it’s up on Jack’s!
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC |
#1255 |
Collector of Projects
Pieced together and test fit the Hydro-Boost system again. Made a bracket for the Wilwood proportioning valve to hang off my CaptainFab firewall mount. I was going to use -AN flex lines but hard lines will be cleaner and take up less space. I still need to plum the -AN Hydro-Boost lines and they would take up the same space ...
#1256 |
Active Member
![]() Join Date: Sep 2009
Dropped it off at Alaska Marine Lines in Seattle to load onto a barge for the trip home to Alaska.
#1257 |
Active Member
![]() Join Date: Jun 2021
Nice looking K5..I really wish I hadnt sold off the orig front seats for mine
#1258 |
Active Member
#1259 |
Are those utility bucket seats?
#1260 |
Active Member
Major depression just sets in....I took my orig number matching engine block and heads in for machining and the guys just called and said my block is cracked....I need to have a drink now
#1261 |
![]() Join Date: Mar 2009
On the bright side, small blocks are fairly cheap and not having the original drivetrains doesnt effect the value of these trucks the way it does on some muscle cars. Don’t be too depressed.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
#1262 |
Active Member
#1263 |
![]() Join Date: Jan 2013
I have 2 3970010's one 30 over 1 standard around he 605 210 area so cal standard block $150 30 over short block $100
#1264 |
Active Member
That may be a option...I will let you know..I am going to think on this for a couple of days.
Have they been checked for cracks and any issues? |
#1265 |
The long block was in my truck with low oil pressure. I've had the other so long I cant remember, but I wouldn't have saved it
#1266 |
Active Member
690 I will send you a PM with my number.
I chilled for a bit and feel better. lol ..I decided to pull out a core motor for a different build and I will take it apart to see if it is good...I will still need a block to not waist all the other good parts. looks like the core motor is the same block so it will work if good |
#1267 |
Pics to follow but priming the new fenders and hood for my 72 K5. Switching back to the 72 from clip vs. the 68 that is there now.
And kudos to the kid in Taiwan that put the adhesive backed foam shipping pads on the fenders. I am not sure what type of adhesive was used but it would hold the space shuttle together. I used everything I had and ended up sanding it off with a DA and 80 grit. That guy is onto something with that adhecive foam pad. Scott |
#1268 |
To the top
#1269 |
The LuvShack Garage
Dreamed of it coming home to celebrate it's 50th anniversary...
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#1270 |
![]() Join Date: Aug 2007
I finished up seat frame repairs with new springs and paint.
Just for the fun of it |
#1272 |
![]() ![]() Join Date: Sep 2008
I changed the brake booster and master cylinder on my son in laws Blazer.
#1273 |
Carpe manana
Had reproduction dealer license plate frames made based off a photo I have of an original. Still chasing an original example.
#1274 |
![]() Join Date: Jun 2005
those are cool. which vendor did you use for yours?
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
#1275 |
Carpe manana
Thank you. Brad Barrie made these. He's got a site on FB. If you need his email address shoot me a PM.
