#26 |
Special Rear Axle?
I noticed today that the rear axle much more closely resembled the rear axle in my GMC than the round cover of my last Chevy... and then I saw it.. a "45" stamped on the housing.
A Spicer 45 in a Chevy? I thought these only came in the GMC? Based on the rest of the truck, the owner didn't appear to be the swap-it-out kinda guy, so I'm curious how that got there. Someone on the HAMB said that it indicates a positraction rear, but thats a rare option for such a plane-jane truck and I doubt that is what I'm looking at. Anyone else find a Spicer 45 rear in their Chevy?
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
#27 |
Re: 1959 Chevy Apache Short Step "Goldilocks"
Well after doing more research, it looks like the only way a Spicer 45 ends up here is when using Positraction, so that's pretty exciting! This is a somewhat rare option.... now I have to decide if I want to swap this into my GMC Suburban pickup that also has a Spicer 45, but didn't necessarily come factory with Positraction. They had the fast-cruising 3.07's back in 56, but no posi option...of course if I found a 3.07 gear set in there, it would stay!
While waiting for parts to arrive and taking a break from wrestling with doors (the passenger hinge pocket is also crap and the caged nut was set free to spin for eternity), I decided to see what else is wrong with this old girl. I used a spare gauge cluster I had to replace a missing speedo needle and Both odo's looked bad, so I took the easy road here. I didn't have a new odo handy and I dont need to report miles to the DMV here, so eh. I found some fried wires/melted plastic terminal insulators... not a good sign! Without rewiring the whole truck, anyone have a simple/economical how-to for adding a basic fuse block to a fuseless factory 59? The wiring is so strange with how things join at ammeters, on relays, etc. We really need a write-up on how to add some fusing and improve the factory wiring without needing an ez-wire and starting from scratch.
#28 |
I also had a crack at rebuilding my first distributor. It's quite easy, actually, and I don't know why anyone would just swap out bits when the whole thing comes apart with 5 screws/bolts and a pin. Relaxing job, 10/10 will rebuild the next one that comes along.
I left out some of the good bits for now, as I'm doing the HEI conversion found HERE
#29 |
Making progress on a few things
There are so many things to do with this truck just to get it working again... forget about customization. Working doors, hinges, electrical, etc.... just taking off the muck is a task by itself!
I managed to get more crud off of the engine. I've been scrubbing some areas down with old gas since its good for nothin else, and I've done another round of power washing since this step but it still looks pretty far from decent.
#30 |
Quick door latch fix
Both interior door handles had broken springs and as far as I could tell, you cant buy just the springs. I removed them, welded them back, and replaced them. Handles actually open the doors now!
These are those little projects that take a whole afternoon/evening and all you have to show for it is something just doing what it's supposed to do! Sure is nice to open the door though (=
#31 |
wet sanding
While I was messing around with the door and fussing with dents and fitment, I took a break from the hard stuff to see how easily the old primer would come off the factory Frontier Beige paint that I love so much... it came off relatively easily! High grit and plenty of water and I didn't blow through.
#32 |
New body tools
I got some new body tools to play around with, including one tool I already owned that became a cab straightening device. Worked great! I pushed the bottom step against the frame and while creating tension there, I smacked the dented cab mount to straighten it out and help keep the step in it's new location.
I knew it worked because I had to remove and realign the door completely, which took a couple of afternoons and some profanity.
#33 |
More fixing crap wiring
I pulled the ignition only to find every terminal had a red wire attached to it, crimped to another wire, sometimes crimped to a THIRD color. I hate this crap so much...
I like when the colors match the schematics, so I ordered some bits and ran fresh wires, and soldered/shrank the connections instead of these crimps. Sure, the old wiring might have worked, but I want to help me and the next guy out, and the vintage style insulators are cheap happiness.
#34 |
HEI Distributor converted
I finished the HEI conversion to the distributor today, and I had to order a second reluctor since i filed the first one incorrectly. I went much slower on round two and got a nice fit this time. After making the adapter plate that allows me to switch back to points anytime, I got it assembled, adjusted, and routed the wired out after notching the wall above the prior hole for the cap negative terminal wire. New vacuum and we're ready to install!
I made up a mount for the HEI module but I need to get some dielectric grease behind it before I secure it up. Once that's wired up I'll get some photos.
#35 |
i never expect it to work as well as it does, but one cheap can of foaming engine degreaser and a warm water pressure washer does AMAZING work. blast, foam, blast, foam, blast and you could eat off an old engine.
that's freakin awesome about the primer coming off! |
#36 |
I've had pretty good results with oven cleaner. Castrol super clean also works pretty good.
Going back a few pics, it looks like your cab mount/floor support has a rust hole at the door step/hinge pillar end. That will give you door alignment issues until fixed if that's the case. Cool idea on the hei convo. Is that something you made up or a kit? |
#37 | |
Yes I was very stoked about the primer... It's going to a fun have-a-beer-sand-the-primer type of activity, just a little at a time. Granted the body still looks like crap nearly everywhere, so I'm not sure what I'm really accomplishing.
#38 | |
That might be an optical illusion, but even so, this cab is still not perfect and never will be. I got the door to latch and that was my big victory (= It can be purchased as a kit, but I DIY'd it. Check it out HERE. I think this is usually something reserved for a nicer build, but I liked the experience and knowledge that comes with it, and I'll take a hotter spark any day if I'm going to get this thing running.
#39 |
oh yeah, mine is just a basic washer too. i just run my hose from the slop sink and turn both hot and cold on full. when i ran just the hot i melted the grease out of the pump and had to open it up to get it working again. warm is within the limits in the manual. anything but straight cold for cleaning grease makes a huge difference.
#40 |
My truck broke a mans leg.
While working on some of the smaller bits here and there, I noticed that the axle was bent... the story started forming now.
One big event happened in this truck, and I wanted to know what it was! So using the name on the title I have, I traced back to the oldest relative of the title name, and called the man. An 85 year old kind gentleman answered and explained that it wasn't his, but he knew the owner. A gold prospector who used to sleep in the camper while he was out sniping for gold, he got run off the road one day and the truck flipped over into a river and landed on a small island, breaking his leg in the process. And I had already named this truck Goldie.. how about that!! So now that the dents and dings have a story, their value just increased! I asked if he had any photos of the truck in its heyday and he did, but he lost them all in a fire.
#41 |
Swapping out bent parts
I got lucky and found what I'm always looking for... good used take-off parts for someone doing an upgrade. A local guy was swapping to a crown vic front and had his front axle and springs up or $50...it had newer brake lines and shoes, so it pretty much paid for itself!
Come to find out the eyes of my leaf springs were toast, and the springs that came with this axle were in good shape still... so I got a whole lot value out of this purchase and saved some time doing the front brakes. Check out how worn these spring bolts are!!! NOS bolts from ebay are on their way.
#42 |
New bench seat
I also picked up a correct 59 bench seat to replace the huge 60-66 bench that didn't fit.
It's a brown fabric that's faded by the sun... I might try a fabric dye, or just leave it as is for now.
#43 |
![]() Join Date: Aug 2010
You Go Dave
Coming along nicely . Has the old bitty down the street said anything yet ?
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#44 |
If she has, the city hasn't stopped by to let me know, yet. The last time they did, they found nothing wrong and said that they may just ignore future complaints...
#45 | |
Re: My truck broke a mans leg.
Jan's 53 |
#46 |
Oh no, I didnt bother keeping all the dirt and crud from the cab... I could have panned it!!
#47 | |
#48 |
That's a great idea! I will have to do that. Not sure if anyone wants to see this ole girl at a car show, but ya never know (=
#49 |
Oil Pump works
So in order to continue to eliminate future variables if I have trouble with this 235, I pulled the oil pan to check for crud/metal and found... oil. Which is great! There was a small amount of water in there, but not much, and I've pressure washed the heck out of this engine a couple of times so that doesn't surprise me.
I did some casual (not perfect) bodywork on the pan to get the big dent out, cleaned it up, and then used it as a cleaning pan for the oil pump. Seemed like a good idea at the time ![]() I tested the oil pump with a screwdriver, just spinning it by hand like I was starting a fire with a stick, and it pumped the solvent through just fine, so I cleaned up the pump a bit, displaced the solvent left in the pump with oil instead, and re-installed. Now if I don't get oil pressure or oil to the top end, I know its not the pump at least!
#50 |
HEI Ignition progress
I had a spare hour or so in decent weather after the sun went down today so I finished putting the coil and HEI module together with the heat sink and the mount I made.
Some black paint and clean looking wires with heat shrink and I'm on to the next task.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
