Old 06-16-2021, 09:59 PM   #1
Awann99
Which AC compressor for r134 AC?
I bought all the factory stuff I need to convert my heater truck to AC. I was going to go with vintage air but wanted to be able to pull in fresh air because the south is very humid.
Anyway. I think I have figured out most of the stuff I need to do a r134 conversion when I install everything. The only thing I am still up in the air about is the compressor. I was looking at an AC delco A6 compressor from rock auto. Would that work without pulling too much HP away from my engine? Is the sanden a better option? Any more options? I want to be able to stay the coolest and use as little HP as possible. I’m pulling 16.5 mpg at 70 with my 350/sm465 307 rear right now and would I like to not take it down too much by adding AC.
I also will usually drive the truck at 1300-1500 rpm in town. It just putts. I drive it like an old man (no offense to any old men). Would the A6 even work well at idle or low rpms?
Thank you.
Awann99 is offline   Reply With Quote
Old 06-16-2021, 10:42 PM   #2
body bolt
Re: Which AC compressor for r134 AC?
I drive like you do. I used a 4seasons aluminum A6 which works fine. Since I bought that thing I've heard some have had them fail. If I were to do it again I'd get a rebuilt GM/Delco/Harrison/Frigidaire. I used this condenser with the Vintage Air mount. I don't notice the HP loss and it gets plenty cold.
Originally Posted by Awann99 View Post
I bought[ all the factory stuff I need to convert my heater truck to AC. I was going to go with vintage air but wanted to be able to pull in fresh air because the south is very humid.
Thank you.
body bolt is offline   Reply With Quote
Old 06-16-2021, 11:40 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'd use the stock type A-6 compressor if the conversion uses a POA valve adjusted for 134. If you are going to a switch to cycle the compressor, use the R-4 compressor, because the A-6s don't suffer cycling gladly and fail fairly quickly, based on what I've seen over the years, here. You probably already know, but the oil for a 134 system is different.
~Steven
Simi Valley, CA
Old 06-17-2021, 09:50 AM   #4
weq92f
weq92f's Avatar
I run the A6. Next time it fails...I'm replacing it with a Sanden.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-17-2021, 09:53 AM   #5
Davidf
+1 Factory a/c system, use the A6, otherwise go with Sanden.
Davidf is offline   Reply With Quote
Old 06-17-2021, 10:55 AM   #6
body bolt
Yep, the clutches don't have the surface area to by cycled on and off.
Old 06-17-2021, 11:17 AM   #7
leddzepp
Moderator
leddzepp's Avatar
I use an A10, aluminum replacement for the A6. Factory AC in my 68. No leaks, no belt squealing, been working great for about 4 years now. I used R12 as original. I will never use an A6 again.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 06-17-2021, 11:39 AM   #8
body bolt
Who made your compressor and the part number? When I bought mine a few years ago I understood I was buying an A10 but the manufacturer's description says it's an A6. Mine is a 4 Seasons 58098.
Old 06-17-2021, 11:50 AM   #9
leddzepp
Moderator
leddzepp's Avatar
I don’t recall the manufacturer. I would imagine they all come from the same place, with each vendor putting their name on it. I bought an entire kit from autozone that included the compressor, drier/receiver, expansion valve, and a quart of mineral oil. They called it an A6 replacement but it’s an A10.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 06-17-2021, 11:51 AM   #10
Davidf
I have been the A6 aluminum replacement (four seasons) for years. Works fine. But, it came out with the engine to replaced with a LM7 LS engine...switching to R134a and using the Denso LS compressor. Going to try and sell the engine/700R4 as a package including the compressor.
Old 06-17-2021, 12:32 PM   #11
body bolt
So maybe mine is actually an A10. I'm using ester oil in case I didn't like the R134 result and opted to switch back to R12. With the POA properly adjusted R134 works just as well as R12. I love POA systems!
Old 06-17-2021, 12:45 PM   #12
leddzepp
Moderator
leddzepp's Avatar
I never had any luck with r134 in a factory AC system conversion, even adjusting the poa and other factors. If it works for you, great. I’m happy with r12. I have stockpiled both and use 134 in all of my newer cars that call for it.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 06-17-2021, 01:23 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
What size engine?
~Steven
Simi Valley, CA
Old 06-17-2021, 10:57 PM   #14
70cst
70cst's Avatar
Who sells the rebuilt GM/Delco/Harrison/Frigidaire Air Compressor (70-402BB) ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-17-2021, 11:46 PM   #15
body bolt
ackits.com was where I bought mine but that was about 20 years ago. It lasted a little over 10 years when I assume the clutch failed as it still turns by hand.
Old 06-18-2021, 08:53 AM   #16
Davidf
What size engine?
350. She's tired and fouls the #8 spark plug. But, no unusual noises, idles fine, and decently smooth when the plug is clean. I suspect bad valve stem seals. She is not a HP monster.
Old 06-18-2021, 09:14 AM   #17
Steeveedee
Who Changed This?
Steeveedee's Avatar
Thanks for the response. I'm looking at replacing or rebuilding the 400 in my truck. That would be a pain to adapt.
~Steven
Simi Valley, CA
Old 06-18-2021, 12:17 PM   #18
Big Kev-O
Big Kev-O's Avatar
"Fresh air" coming from a humid outdoor environment is loaded with moisture and latent heat. The best way to reduce the amount of moisture inside your cab is by recycling the air inside your cab. When air flows through your AC coil it cools off and the temperature falls below the dewpoint. When that happens water is pulled out of the air. Humid fresh air is much harder to cool than the air inside your cab which has already had a significant amount of moisture removed. So if you want a less humid environment inside your truck use a system can recycle the air inside the cab. This is why most modern cars automatically set the AC to recycle when on the max cool setting.
Having a system that lets you open & close the fresh air intake is the best option but max cooling & dehumidification is accomplished when the air is recycled.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
