06-17-2021, 10:01 AM | #1 |
Question - 67 GMC
So, this truck has come up for sale less than 20 minutes from my house and if it's not gone by the weekend I may go take a look at it.
67 GMC long wheel base, six cylinder is all I have at this point. But, from this photo I have to ask these questions: 1. Does this bed look extra long between cab and rear wheel? 2. Is the rear wheel/tire not setting right in the wheel opening? Could it just be the photo?
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
06-17-2021, 10:46 AM | #2 |
Its a Truck Thing......
Re: Question - 67 GMC
67 beds are unique.
The longbeds have the point in the wheel well which did change for later years to the curve. If it was a longer bed you would see the seam at the front of the bed, but no Longhorns in 67. Check the frame for damage and see what is up with the rear wheel. EDIT: After looking at some other 67's it looks normal for the rear wheel. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time Last edited by 71meangreenc10; 06-17-2021 at 10:59 AM. |
06-17-2021, 10:52 AM | #3 |
Possible body swap? Even worse, that might be a Ford under there. Thats a late eighties Ford wheel cover.
Could just be a bad picture, take a look!
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
06-17-2021, 01:22 PM | #4 |
Funny Looking at my 68 gmc it has a 67 box on it the wheel sits more centered then this 67.
The 67 I striped for parts to get the box in the 90s. I do not remember how the rear wheel looked in the wheel housing Body looks good shape price is right I would buy it rear end looks leaf sprung I would convert to truck arm and coils for a nicer ride |
06-18-2021, 12:43 PM | #5 |
Looks like it may have leaf springs in the rear. Maybe the leafs are installed backwards. The perch mounts are offset on the leaf springs but I am not sure if installing them backward would move the wheels forward or back. Check that frame closely and take a look at the driveshaft to see if the slip joint and trans yoke look squished together.
Made in America by Americans |
06-18-2021, 01:05 PM | #6 |
Good call leafs on backwards would push the diff forword
06-18-2021, 01:47 PM | #7 |
All '67 GMC pickups should have rear leaf springs, unless they are Oshawa built Canadian models. If this truck has leaf springs, what may have happened here is the spring bolt may be broken. The is the vertical bolt that holds the leafs together and the head locates the axle. It protrudes down into a hole in the axle spring pad, the head can shear off and allow the axle to slide forward. Easy fix. Looks like it might be a pretty decent truck otherwise.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
06-18-2021, 02:56 PM | #8 |
Only thing I see wrong with that truck is the FORD hubcap on the front wheel!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
06-18-2021, 03:28 PM | #9 |
