#4926 |
Re: What did you do with your truck today, Part 3
mejum - That is a beauty..........
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#4927 |
dang mejum, that gave me a little wood...
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#4928 |
went to a "Hotrod & Hogs" show not too far from home. They had about 250 cars pre registered and were fast approaching 500 by noon. Great cars & great people. Looking forward to more shows this year.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
#4929 |
Three days on and off in the hot sun and I finished stripping down my donor chassis. I'm just using the frame rails but I could not bring myself to just torch it apart. Me or someone else may need something someday. I also wanted to keep from damaging it. I tried a few things but what worked best for me was to drill the head of the rivet, 1/8", 1/4", 3/8" and then pop it off with the air hammer and flat blade. This left a nice divot for the pointy attachment on the air hammer. They were still very much stuck in there. There was no deterioration in the rivets or steel. I thought there would be rust in there. I then took the oxy torch and heated the back side of the rivet head cherry red and they popped right out. I was surprised to see when I took the rivets out of the front crossmember first that the rails were under about an inch of tension. My plan is to use the frame rails to box the chassis on my 53 3100. I bought the chassis from a nice fellow on the Stovebolt in Wisconsin about 4 hours away for $200. He kept the running board brackets. Sorry so long. Thank you for your time.
#4930 |
I got a free truck wash...
#4931 | |
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#4932 |
What do y’all think about moving my 57 cab onto the rear of the frame so I can finish painting the frame and finishing firewall? Has anyone done it?
#4933 |
#4934 | |
![]() Join Date: Aug 2010
The easy way is jack it up from the chassis and put jack stands under the steps and the roll the chassis forward .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#4935 |
Thought about that but driveway is a bit to steep. Garage isn’t the biggest so I want to have as much room as possible to work.
#4936 |
#4937 |
My wrist are sore from dismantling the frame so I spent a few hours working on polishing the back cover on my 6-71. This will be right in front of the windshield on the "hot chick side" of the truck so it has to be polished. I have all the rough grinding done except for the bearing covers. This is a pain but somebody has to do it.
#4938 | |
you can also roll the cab on it's back if you need to modify the floor from underneath. just throw some plywood on the frame and a moving blanket and gently roll it back
#4939 |
Yeah that’s a good idea. I already have motor, tranny, t-case and all that installed. Just catching up now. Will be taking winders out this weekend to lighten it up. Previous owner really screwed up the dash/ radio. Nervous about attempting to do it myself
#4940 |
![]() Join Date: Oct 2016
saw it down in Centralia or Olympia... I don't remember!
#4941 |
I cut up the boat trailer I bought for my chassis jig, table, rack or whatever you call it. It's been in a vacant lot for years and was full of wasps. They mostly attacked the torch. I don't think they understood the problem. I got the 53 in the driveway. This is huge for me. 4 years working on drivetrain and axles and polishing. Now some fun. To me she is still as beautiful as 40 years ago.
#4942 |
I got the girl cleaned out and power washed today. The massive amount of wasps and hornets didn't hold up any better to the power washer than they did to the torch on the frame. I have most of the new parts to finish her including a new tailgate and bed with pockets from Jim Carter. I also have an original grill with heavy chrome and stainless bumpers. She's really not in that bad of shape. It was never driven in Indiana where I live now. I lived in the So-Cal desert when I was driving her. I drove it from LA to northern Indiana and back 5 times, stock. I was a much younger man then. If I was a patina guy it's the real deal. Thank you for your time.
#4943 |
Cool history. When you get her done you'll have to make that drive again.
1951 Chevy Panel Truck |
#4944 |
Getting some holes welded up on the firewall today. Finally picked up a welding blanket for the engine. Ordered some 16 gauge hole fillers from speedway. Finally getting a little progress done everyday.
#4945 |
A friend told me to find a washer that fit the holes, weld them in, and then weld up the smaller center hole.
#4946 |
![]() Join Date: Dec 2015
We got a massage. Wildfire smoke was bad. Didn't want a town picture, took a shortcut.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
#4947 |
Are the little bumps on there to help hold them in place or just manufacturing process?
#4948 |
#4949 |
Just a quick question.
Can someone help point out exactly what holes I should keep? I plan on keeping most things in stock locations. Battery tray Aftermarket heater assembly Wiring grommet holes High beam switch Have to install brake booster Plan on just having the bare minimum |
#4950 |
my brake lights stopped working. its yet another witing issue. really the only things that ever go wrong with my truck. i paid to have it wired and now i wish i had done it myself. i checked fuses and grounds. they were all fine. i put a power light on my colum plugs and got nothing. nothing for brakes or signals. hell not a single flash on the power light. im kinda stuck at this point. i put in an email to tech at Ididit to see what they have to say. i dont like things that kee me from driving my truck. ive been doing a lot of light body work and priming to make it look nicer. its getting there.
