Correct black paint for stock steel wheels?
I have one good original wheel with almost no wear or weathering and the original black paint seems to be somewhere in the middle of chassis black and gloss black(?) anyone know how I could source correct paint for original wheels in a stock application?
Steve weim55 Colorado Posted via Mobile Device |
Re: Correct black paint for stock steel wheels?
I'd like to know too. I've never read anything in GM literature other than "black." I would've assumed that they'd be the same gloss black used on the body, since two tone trucks used body colored wheels. It makes sense though, that the wheel manufacturer may have used a semi-gloss black and that GM just left them that way unless it was a two toned truck. Hopefully someone can enlighten us.
![]() Join Date: Aug 2010
A quality semi-gloss black will get you close. I'm not even sure if the factory was totally consistent on the level of gloss used on standard wheels. I can tell you it's not high gloss, and not satin either, but somewhere in between.
![]() ![]() ![]() Join Date: Jan 2018
That's good to know, thanks. I've got a set of wheels that need some black paint on them for that stock-ish look
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
![]() ![]() Join Date: Apr 2012
Possible reason for the different black you might be seeing is there were several different wheel makers for GM. Im assuming the wheel maker painted them black before being shipped . Definitely not gloss , I would and always have gone semi gloss
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#6 | |
Agreed, the middle, kinda.... Seems to be shade just slightly flatter than gloss. I might just hit the paint supplier and ask for just that. Steve weim55 Colorado |
