06-19-2021, 09:49 PM | #1 |
WTB Rear Axle Leaf Spring Plate
I need 2 of the rear axle plates that sit under axle, the axle u bolts go through plate and secure axle to leaf springs.
Needed for a 1972 Blazer. I'm sure all half ton K trucks use this attaching plate. Good chance 2WD trucks with leaf springs use the same plate. PO lifted Blazer and changed axle/leaf spring setup. The u bolts are supposed to face down. PO added lift blocks and a round u bolt that faced up. The improper plate on Blazer is on top of the leaf springs and is incorrect. I'm attaching a photo of the correct attaching method and you can see the plate under the axle...I need 2 of these. Thanks for any help.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
06-21-2021, 02:53 PM | #2 |
Re: WTB Rear Axle Leaf Spring Plate
I should have a set. pm your cell i`ll send a pic.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
