Old 06-20-2021, 04:04 PM   #1
macdaddy70
Help with wheels after disc conversion
I have done searches and cant find what I am looking for. 1970 LWB GMC with original 15" wheels. Recently had all new MOOG suspension and CPP disc brakes/booster/mc/prop valve installed.
Wheels are in place, but had to add washers to clear calipers. Backspace of original wheel is about 3 7/8". Approx 1/2 inch of washers had to be added for clearance. Does that mean that I need to look for a wheel with roughly 4.5" backspace?
I wanted to stay with stock look, but going to aftermarket aluminum, dont want to use a spacer.
Pics meant to show space from rotor to back of rim and clearance from caliper to inside of rim.
macdaddy70 is offline   Reply With Quote
Old 06-20-2021, 04:43 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Help with wheels after disc conversion
I sure hope your not driving it like that ? those wheels are destroyed .
Old 06-20-2021, 05:37 PM   #3
gmc684x4
Drum brake wheels do not fit with disc brakes
The inside area hits the caliper
gmc684x4 is offline   Reply With Quote
Old 06-20-2021, 05:43 PM   #4
Mike C
Mike C's Avatar
You kept it 6 lug? If so 71-87 6 lug 4x4 rims should work just fine.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-20-2021, 05:48 PM   #5
macdaddy70
No I am not driving, but want too. Looking for wheel info so i can get the right fit on the first try.
Old 06-20-2021, 05:59 PM   #6
geezer#99
geezer#99's Avatar
Try this.
https://www.hotrod.com/articles/ccrp...heels-fitment/
Old 06-21-2021, 04:13 AM   #7
BigBird05
Its not the back spacing that is the problem. Its the design of the rim where it curves up. The rims were redesigned for more clearance when the trucks went to disc brakes.
BigBird05 is offline   Reply With Quote
Old 06-21-2021, 12:31 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Look at this thread,...
http://67-72chevytrucks.com/vboard/s...d.php?t=560599
Keith
Convert to disc brakes.
Old 06-21-2021, 12:35 PM   #9
lolife99
lolife99's Avatar
Also do a search about backspacing.
Backspacing is the measurement taken on the BACK SIDE of the wheel.
With 15” wheels you want no more than 3.5”-4” of backspacing.
Even then with drop spindles you may need to grind a little clearance on the lower control arm.
Keith
Old 06-21-2021, 12:48 PM   #10
MikeB
MikeB's Avatar
CPP strikes again! On my 69 C10 I used 73-87 spindles, rotors, and calipers with 73-87 8-inch rally wheels. Zero issues. Had a shop re-drill the rear axles for 5-on-5.
Too bad Early Classic Enterprises is gone. They sold stuff that actually fit!
Did you call CPP?
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 06-21-2021, 01:01 PM   #11
lolife99
lolife99's Avatar
Did you call CPP?
This isn’t a CPP problem.
The proble is trying to fit drum brake (pre-71) steel wheels on a disc brake rotor.
Keith
Old 06-21-2021, 03:09 PM   #12
67C10Step
67C10Step's Avatar
Agree. All my CPP stuff fit perfectly but I knew my original 67 wheels would not fit. Went with 15x8 rally's with the correct back spacing. All fit fine with no rubbing issues anywhere.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 06-21-2021, 03:28 PM   #13
MikeB
MikeB's Avatar
I stand corrected. I'm just too quick to jump on CPP, having dealt with them in the past.
Mike
Old 06-21-2021, 07:15 PM   #14
macdaddy70
Thanks for responses. I ordered a couple of wheels today that should fit after doing more research. Will know for sure in a few days.
Old 06-21-2021, 08:46 PM   #15
lolife99
lolife99's Avatar
I also hate to defend CPP because I’ve had issue with them also.
Summit Racing seems to take the guess work out of buying CPP products.
I would never buy directly from CPP.
Keith
