Old 06-22-2021, 10:56 AM   #1
ChadW
clutch pedal removal on a 66
I have a 66 that was originally a manual trans truck...I am putting a 700r4 in my build so i dont need to clutch pedal anymore...It looks like it comes out fairly easy by removing the spline lever and bolt on the gas pedal side and it will then slide out of the brake pedal "tube"...my question is, is this the correct way to eliminate it? or does the brake pedal mechanism still need that hardware connected up to function correctly? Other way was just gut it off up high and be done with it....Thoughts??
ChadW is offline   Reply With Quote
Old 06-22-2021, 11:33 AM   #2
Southcity
Southcity's Avatar
Re: clutch pedal removal on a 66
Don't cut it, removal is quite easy and brake assembly does not require it to remain in order to function. Helpful diagram from LMC truck below:
https://www.lmctruck.com/1960-66-che...dal-components
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 06-22-2021, 01:04 PM   #3
ChadW
Perfect...I got it out with no issues...Now i need to figure out what to use for a gas pedal..just running a sbc...This is all i have in my cab right now..https://photos.google.com/photo/AF1Q...1TyDnYaMzLzAij Am i better off going with a 72-86 pedal and cable? think ive seen some write ups on how to do that..
Old 06-22-2021, 01:41 PM   #4
Southcity
Southcity's Avatar
I was unable to access your google image but in a 66 there should be two round metal knobs on the floor, the gas pedal has pockets for these to sit in. LMC truck does sell these (https://www.lmctruck.com/1960-66-che...r-rubber-parts) but there are other sites that should carry them too (i.e. Brothers Trucks, Classic Car industries, GMC Pauls etc.)
Old 06-22-2021, 01:48 PM   #5
ChadW
Old 06-22-2021, 02:17 PM   #6
Southcity
Southcity's Avatar
Thanks, looks like you are missing the gas pedal studs down on the floor (the two holes in the floor at the base of where the gas pedal would be). Not sure where you find them, but here is a link to an ebay item as an example.
https://www.ebay.com/itm/17357878988...caApeoEALw_wcB
Old 06-22-2021, 02:26 PM   #7
ChadW
Any advantage/disadvantage to running a throttle "rod" instead of a cable? guessing if i stay with what i have "stock" in the cab already i will be running a rod...700r4 tranny...
Old 06-22-2021, 02:37 PM   #8
Southcity
Southcity's Avatar
I run a 700R4 and am running a throttle rod on my setup. I used the original gas pedal assembly at the firewall (same as yours) but then used a swedged aluminum throttle rod with heim joints from there to carb. Purchased the aluminum rod and heim joints at Speedway. For the throttle heim joints, you would get a right and left hand thread so you can easily adjust. Don't forget the jam nuts!
Swedged throttle rods:
https://www.speedwaymotors.com/Searc...wedged%20tubes
Throttle heim Joints:
https://www.speedwaymotors.com/Steel...tud,34302.html
Jam nuts:
https://www.speedwaymotors.com/Searc...art:Jam%20Nuts
Old 06-22-2021, 02:46 PM   #9
ChadW
Jam nuts:
awesome..tks...dont go out of your way, but if you have a pic of your setup, on the engine side, Id like to see it..
Old 06-22-2021, 03:41 PM   #10
Southcity
Southcity's Avatar
Difficult to get a good picture
At firewall
Old 06-22-2021, 03:45 PM   #11
ChadW
Attachment 2109489
Attachment 2109490
At firewall
Attachment 2109491
That helps...Thanks!
Old 06-22-2021, 10:14 PM   #12
cwcarpenter98
cwcarpenter98's Avatar
I converted mine to a cable to better work with my carb linkage, but I used a 73-87 pedal. I don't recommend using a 73-87 pedal. It doesn't fit great with the firewall. I had to bend it a lot. I am going to put a 71-72 pedal in it at some point
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-22-2021, 11:44 PM   #13
rws1012
I am going to use a 7004 trans in my 66 also. Since i am using the original 250 six cylinder will I have to just remove the clutch pedal only and use the original setup on the gas pedal? Also going to use a column shifter out of a 69 truck.
rws1012 is offline   Reply With Quote
Old 06-23-2021, 11:43 AM   #14
Southcity
Southcity's Avatar
You should be able to just remove clutch pedal assembly and use your existing throttle assembly setup.
Old 06-24-2021, 01:28 PM   #15
deldridge
Chad, I need a clutch pedal, someone cut mine off and I am putting a manual trans back in mine. let me know if you want to sell yours
deldridge is offline   Reply With Quote
Old 06-26-2021, 04:38 PM   #16
pdxhall
pdxhall's Avatar
Here's my setup. I've also got a 700r4 and you can see the cable for that and I modified the flat piece so I would be sure to get full throttle. As for the gas pedal, those little ball attachments are needed but I can not recommend LMC for those. I bought a pair and they did not fit right and are not the same as the originals. Go to one of the suppliers mentioned above.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
