Old 07-03-2021, 02:57 PM   #1
truckin 79
What does your oil pressure gauge show at idle?
Mine shows a tic above 0 when warmed up at shoots to 40 while driving. What about temp gauge mine does not ever go any higher then what is shown in picture.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 07-03-2021, 03:04 PM   #2
Nick_R_23
Nick_R_23's Avatar
Re: What does your oil pressure gauge show at idle?
As with any oil pressure problem, you should verify with a known hood, QUALITY mechanical pressure gauge. If you still retain the same low reading, you have worn camshaft, connecting rod, or crankshaft bearings.
Nick_R_23 is online now   Reply With Quote
Old 07-03-2021, 10:20 PM   #3
Dead Parrot
If you have an electric oil gauge, make sure the sender is matched to the gauge. IIRC - there are 3 pressure ranges. My 75 has a mechanical and shows near max at speed and around 15~20 at idle once hot. No idea how accurate a 45+ year old gauge is.
Temp gauge behavior is normal if the OEM sender was replaced. Most aftermarket senders don't come close to matching the temp curves of the original. Grounding the sender end of the wire should give a max temp reading on the gauge. There are several threads on temp gauge - sender match ups.
Dead Parrot is offline   Reply With Quote
Old 07-06-2021, 02:09 PM   #4
72c20customcamper
72c20customcamper's Avatar
What oil are you running ? My owners manual calls for 15w40 in the summer on my 85 with 30w the oil pressure is noticeably lower when it's hot.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-06-2021, 10:04 PM   #5
karlbenz
mine is about 15 at idle. 60-65 goin down the road. motor doesn't have many miles on it
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 07-07-2021, 03:22 PM   #6
truckin 79
Well the oil pressure sender I bought from Autozone said it was a 70 psi sender. I thought a sender was a sender. So I need to find a 60 psi sender to match my gauge, is this right ?
