Old 07-07-2021, 08:41 AM   #1
sick472
sick472's Avatar
What does this vacuum pod do?
My 85 K20 has a vacuum pod just above the brake booster. I have owned it for 7 years now and the vacuum line (going to the right) has never been hooked up to anything. I'm swapping motors and thought, now would be the time to fix it or eliminate it.
What does this do?
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 07-07-2021, 04:10 PM   #2
Dannyboy1966
Dannyboy1966's Avatar
Re: What does this vacuum pod do?
What does this do?
That is the low vacuum pressure switch for the 700R4 transmission. It releases the lock up torque converter when you stomp your foot into the gas, in connection with the TV cable for passing gear. Should have a blue wire coming off the brake light switch, and a wire from the pod down to the transmission.
Dannyboy1966 is offline   Reply With Quote
Old 07-07-2021, 05:13 PM   #3
kwmech
Ya know i thought it was a transmission control for the 700 but him saying it is in K20 kinda threw me off as I don't know of any 3/4 tons with that trans
Old 07-07-2021, 05:16 PM   #4
sick472
sick472's Avatar
Thanks for the reponse Dan! I'll have to check the wiring to see if it is hooked up.
Where should the vacuum hose be hooked to? Currently it is hanging loose in the driver's side fender. I doubt there is any appreciable vacuum in there to help out the transmission...lol
1972 C10
1985 K20
Old 07-08-2021, 05:33 AM   #5
GM72K10
Next!
GM72K10's Avatar
I had a lite duty K20 (didn't have a full floating 8 lug rear) that had one. Apparently not very common.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 07-08-2021, 08:12 AM   #6
sick472
sick472's Avatar
I'm sure it's a 700R4 and the fact that the switch is not hooked up to vacuum... it makes sense as the lock-up wiring at the transmission has been unhooked in the past as well (I checked last night). So, it appears that neither the wire at the transmission is connected nor the vacuum hose at the low vacuum pressure switch. Something must be up with the lockup function of the convertor/transmission.
I'm skeptical to hook it all back up, but (should I feel punchy) where should the vac hose off the switch be connected?
1972 C10
1985 K20
Old 07-14-2021, 11:03 AM   #7
sick472
sick472's Avatar
I have decided to have the transmission rebuilt since the motor is out an also needing a rebuild. My rebuilder has commented that the transmission will overheat on a long trip without the lock-up functioning. I have made several 2 hour trips with it like this and have not burned it up, but I would like to get the lock-up working since I will end up with a rebuilt motor and transmission.
Where does the vacuum line hook to for the vacuum source?
1972 C10
1985 K20
Old 07-14-2021, 01:24 PM   #8
kipps
The semi-float 14-bolt was not just a light-duty option. It was installed even in the heavier "c6p" 8600-gvwr 3/4-ton trucks. Evidently, GM considered it heavy enough for large payloads.
GM did install the full-float 14-bolt in the big-block c20 trucks. My theory is they assumed that combo was being purchased to tow trailers with. The larger ring gear on the full-float axle would hold up better to towing.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 07-21-2021, 05:07 PM   #9
Dannyboy1966
Sorry it took so long to get back with you, I was in the hospital, thought the Covid had gotten hold of me, thank god not. Anyway that vacuum line just connects to manifold vacuum, so than when you stomp into the motor and vacuum drops, it causes the lock up torque converter to release. One wire from it goes through a blue wire into the firewall to a switch on the brake pedal, normally part of the brake light switch unless it has cruise control, then it uses that switch for the power. The other wire goes down to a square 4 wire plug on the side, halfway between the shift linkage, and the governor dome on the driver side. Normally it's just one wire from factory, or in my case I ran a seperate ground wire to a solid ground on the engine. Factory used a 1 wire pressure switch inside the transmission, using the transmission as a ground to the engine.
Old 07-22-2021, 08:13 AM   #10
sick472
sick472's Avatar
Thanks a million Danny! No worries about the post timing as the transmission is still in the truck, but only a couple hours away from hitting the floor and going to get rebuilt....glad your back and good to go! Thanks again, your response is appreciated.
1972 C10
1985 K20
