Old 07-08-2021, 11:10 AM   #1
nitne
5.7 liter Caddy engine swap or 5.3 Chevy engine?
Has anyone swapped a 5.7 liter caddy engine into their 67-72? I have searched the forums but can't seem to find anything. I have the option of going with the 5.7liter with trans and all other parts for around 2k or a 5.3 liter with all related parts for the same amount. What would you guys do?
Its all Ball Bearings these days.
70 chevy C10 In pieces. Any body got some rubber bands I can borrow to put it all back together.
nitne is offline   Reply With Quote
Old 07-08-2021, 12:21 PM   #2
68Gold/white
Re: 5.7 liter Caddy engine swap or 5.3 Chevy engine?
What year is the Cad engine, what model of Cad???
68Gold/white is offline   Reply With Quote
Old 07-08-2021, 01:31 PM   #3
Caddylackn
Caddylackn's Avatar
Cadillac never made their own 5.7 liter motor, but they did put Chevy 5.7 and Olds 5.7 motors in some Cadillac cars starting in the 80s.
I would think you would be happier with a 5.3 LS motor than the 40+ year old 5.7 (350) that made only 180 - 200 hp when it was new. $2k seems high for a 5.7 unless its a fresh rebuild. The only 5.7 that's worth having would be the Vortec headed 5.7 that came in the Escalade from about 96 - 2000 with about 260 hp and good torque output but that would have a four wheel drive transmission.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 07-08-2021, 02:52 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
‘99 was the first year for the Escalade, only 99-2000 have the L31 vortec 350.
Tyler
57taskforce is online now   Reply With Quote
Old 07-08-2021, 04:38 PM   #5
LS short box
I would do the LS in heart beat.
Old 07-08-2021, 05:37 PM   #6
54blackhornet
54blackhornet's Avatar
Why not a 500 ci Caddy ? Been done often so not a problem installing it, big time torque.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 07-08-2021, 08:36 PM   #7
jimijam00
Neither. Spend that 2K on building an old school big block.
jimijam00 is offline   Reply With Quote
Old 07-08-2021, 08:57 PM   #8
70STOVEBOLT
70STOVEBOLT's Avatar
Originally Posted by jimijam00 View Post
neither. Spend that 2k on building an old school big block.
this
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 07-09-2021, 11:00 AM   #9
Big Kev-O
Big Kev-O's Avatar
I have a 5.7 L31 similar to that caddy that I scored for $650 without a transmission. It looks more period correct but a 5.3 could easily make the same power while getting better MPG. That said you would need engine mounts & harness work to get the 5.3 installed. If the 5.3 & transmission has low mileage $2k is fair. Crate engine prices have gone way up and rebuilding a big block is going to cost way more than $2k. I would go with the 5.3
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 07-13-2021, 02:04 AM   #10
nitne
This is a 5.7 LT1 out of 1995 fleetwood with 134k, its the entire car, so I would have the trans, ECU and wiring harness and all the other bits I might need. Then I can part or scrap the remainder of the car. What do you guys think?
Old 07-13-2021, 11:09 AM   #11
kwmech
I'd pass on just the ignition system on that thing alone
Old 07-13-2021, 11:12 AM   #12
titan1587
5.3 all day long for the long distance reliability and mileage
2002 Duramax I love
1971 k10 4x4 longbed 350/350/205 all original
titan1587 is offline   Reply With Quote
Old 07-13-2021, 11:16 AM   #13
kwmech
Yup, convert to something that has some long term support to it, instead of 'yeah I need a coil pac for a 95 cadillac, yeah the one with the coil and plug wires under the water pump'.
fastest pic I could find:
https://www.ebay.com/itm/32466886685...RoCkgIQAvD_BwE
Old 07-13-2021, 11:43 AM   #14
Big Kev-O
Big Kev-O's Avatar
That LT1 has 260hp and is a reverse coolant flow Gen II with Optispark ignition. It is a reliable engine but optispark has some issues. There are solutions available to solve the optispark issues. The 5.3L makes 270-310hp depending on what it came out of. In stock form the performance specs are fairly close so if you don't plan on modifying your engine either will get you down the road. I would not spend $2k on a Gen II LT1. If you are considering modifying for more HP the 5.3 LS would be my choice. There is a huge market for LS performance products.
Old 07-13-2021, 01:09 PM   #15
nitne
Thanks guys, I will start looking for a good donor vehicle. I will start looking for 5.3 L from a 2 wheel drive truck, van or car. Is there any years I should stay away from?
Old 07-13-2021, 10:10 PM   #16
hugger6933
You wont find a 5.3 in a car well you could cause the mote carlos or impalas had them but they are not the same engine your looking for. One place to look is a NPR Isuzu truck they have 6.0's and 4L80E trans in them I have one sitting at my shop so I know. Also be sure you can trace the motor to the truck it came from unless you know the people you are buying from. There are tons of guys that think they bought 5.3 motors and really got the 4.8 motor instead. Once you separate the motor from the truck, you cant tell without pulling the oil pan and checking rods and stuff. The block even have displacement stamped on them but many years are stamped 4.8/5.3. The motor if still in the truck, the vin number will tell you the truth about the engine size. If you find one in a Suburban it will be 5.3 cause they dont offer the 4.8 in them. Hope this helps a bit. Jim
hugger6933 is offline   Reply With Quote
Old 07-13-2021, 10:38 PM   #17
Ziegelsteinfaust
I am a pretty big LT1 guy, and I am swapping a 383 LT1 into my C10 tomorrow. If you like a carb vs fuel injection. The intake manifold is available, but a bit pricey. You can use your standard V8 distributor with a hardened gear swap. With the 4 barrel intake, 1 3/4 headers they are a very strong 325hp engine. Factory exhaust, and intake were big comprises. You can go over 400hp with a cam, but 425 is the limit due to cylinder heads. Go afr, and 500 is pretty easy.
True it is no LS, but it is not a weak engine. I had a LT4 with performance build of unknown specs. It was from a dyno shop who was prototyping parts for Corvettes. It would idle like a baby with a mild lope, and could seriously hang with most things one would actually see on the street.
To put one in a C10. The B body accessories are the best supposedly. I only ran alternators on modified brackets. You just need to notch your cross member. How much I will find out in several months when I add AC back to my truck
Ziegelsteinfaust is offline   Reply With Quote
Old 07-14-2021, 12:08 AM   #18
truckster
truckster's Avatar
As the proud owner of an LT1 Z/28, I can tell you those Optispark solutions aren't cheap. You could get an entire LS engine for what a 24x Optispark conversion costs.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 07-14-2021, 12:55 AM   #19
gmc684x4
Gen 2 Ltd distributors suck
Hit a puddle hard they fail
Plan on replacing it atleast every 2 years
It will be obd1.5 which is obd1 wiring with obd2 port scan tools usually won't read it with out rewiring it
I had a 94 z28 loved it until I learned the issues with the poor dizzy design
For anything more then free I would give it a hard pass
Look for its son gen 1 vortec l31 or better yet find a 4.8 5 3 or 6 liter
I got a good l31 free in a van and a good 5.3 in a truck there out there
gmc684x4 is offline   Reply With Quote
5.3 ls, 5.7 liter
