In Bed Spare Tire Mount Location ?
I really never realized that my C/20 had it until I saw it listed on the SPID. It’s located in the rear, behind the wheel well on driver side. Looking closely I see no holes drilled anywhere up front where I thought they where originally mounted. The bummer is mine was welded in place long ago...thanks
71 C-20 07 Magnum RT AWD |
Re: In Bed Spare Tire Mount Location ?
I think it varied. Some in front of the wheel well.
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
Mine is drivers side in front of wheel well.
I believe mine is in the original location, driver’s side in front of the wheel housing.
Moderator
![]() Join Date: May 2007
This is correct. The bottom of the bracket uses the factory holes used to secure the bedside to the bed floor.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Left Front is correct.
![]() Also - they weren't welded in place, which is another clue that tells me someone relocated yours, probably for farm use to accommodate a tool box or fuel tank in the front of the bed. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I added my own in, driver's side in front of wheel well. I tried it in the passenger's but it created quite a blind spot.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
You guys are correct ! After looking closely I finally noticed the two holes up front on drivers side. I actually like having it located where it is. Now I just need to find the proper style bolt needed to secure the spare...
