Old 07-21-2021, 08:24 PM   #1
64k10burb
64k10burb's Avatar
core support repair
Hi guys, I just picked up a '69 c-10 P/U.
most of the passenger side core support mount holes (for inner fender) are gone.
Can I make a pattern from the drivers side and flip it?
I'm not sure if they are the same on both sides.
Thanks in advance.
Brian
1969 c-10 short/wide/6L LS swap
1964 k10 suburban project
1964 Falcon sedan delivery rescue project
64k10burb is offline   Reply With Quote
Old 07-22-2021, 04:33 PM   #2
cornerstone
cornerstone's Avatar
Re: core support repair
Hey Brian, The core support on my 72 is nearly identical on both sides, so as long as your not intending to win any shows, that'd be a good way to shape your metal to weld in a repair.
You would probably get more responses if you posted in the general area of the forum instead of the builds section.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 07-22-2021, 05:33 PM   #3
64k10burb
64k10burb's Avatar
Thank you!
I did post it there, I can't figure out how to delete this one.
Brian
