07-23-2021, 08:18 AM | #51 | |
Re: Will 15" x 10" wide rim with 4" backspace fit with stock rear?
What year & body style?
07-23-2021, 08:31 AM | #52 |
This is on a '65 SWB fleet. On a stock rear end and approximately 9" backspace...just throwing numbers out there...you don't think a 5" lip would look alright? You're just implying that, aesthetically, it would look better on a narrowed rear with more lip?
07-23-2021, 08:53 AM | #53 | |
Lowered truck? If so how much?
07-23-2021, 10:26 AM | #54 |
I see what you're saying. Truck will be on bags with a c-notch. I don't have pictures to base this on, but I think I would be ok if the wheel only had a 5" lip. I don't mind the big lips a lot of people are running but I would like to have a more "classic/timeless" look on my truck.
07-23-2021, 01:18 PM | #55 | |
The 63-66 bed insides are different vs 67-72's so it's going to depend on how much cutting-up you're going to do to 99% dial in your BS needs but your proposed number is in the ballpark. Adding disc brakes can impact your track width as well so you need to verify the rear end dimensions w/the brakes you plan to use or pad your needs enough to cover the possible 'what ifs' (wider/narrower).
07-23-2021, 02:24 PM | #56 | |
The picture is not the best , however that’s the combination.. Missed your backspace at 3”, mine are 4” backspace, which actually all four wheels are off and for sale Last edited by MT65; 07-23-2021 at 02:27 PM. Reason: Lack of intelligence |
07-24-2021, 03:15 PM | #57 |
But Found Her 25yrs Later!
Nice green.
07-24-2021, 09:48 PM | #58 | |
I should have been more clear I guess...what I mean by classic/timeless look is that the wheels im looking at give a nod towards the 60s era with a more modern look when it comes to the size of them. Im fine with having to tub the wheel tubs and trim the wood floor as needed...other than that I don't want to have to trim anything else. So, you think I'd be ok with buying my brakes for the 12 bolt and going that route? I'd hate to buy brakes for my 12 bolt and then wheels/ tires won't fit and then I need to go with a narrowed 9" rear.
07-24-2021, 10:45 PM | #59 | |
07-24-2021, 11:34 PM | #60 |
