Old 07-25-2021, 10:33 PM   #1
bfr57
bfr57's Avatar
Hydroboost Question
I found a hydroboost out of a 2005 Tahoe. I opted not to take the MC from donor and get a new one. I've done a HB swap in my hotrod and it works great, so getting this one mach'd up in my '72 for better brake performance. When I saw this one in the Tahoe, it had a return line from the MC reservoir to the HB; it was just a standard rubber line. This line went from the bottom of MC reservoir to the return line on the HB shown in the pic. Got it mounted and then it dawned on me that the brake system is combined with the PS system. What the heck? How does this work? I'm positive that line went from MC to HB. I know I can find another MC reservoir without the nipple and add a return fitting from HB to the PS pump, but just trying to wrap my head about the 2 systems combined?
bfr57 is offline   Reply With Quote
Old 07-25-2021, 10:49 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Hydroboost Question
Obviously anythings possible, but I've not seen one plumbed that way...interesting...I would think you could just cap it off
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-25-2021, 10:58 PM   #3
mongocanfly
I found this pic
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-25-2021, 10:59 PM   #4
mongocanfly
Does your new hydro have all 3 lines coming from it?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-25-2021, 11:31 PM   #5
bfr57
bfr57's Avatar
It does. The HB has the regular 3 connections. It's that low pressure return line that was connected directly to the MC that has me confused.
Old 07-25-2021, 11:32 PM   #6
bfr57
bfr57's Avatar
I found this pic
Yup, that's what it looked like.
Old 07-25-2021, 11:32 PM   #7
mongocanfly
Does seem odd
Was the master reservoir doubling as a reservoir for the power steering pump...I know some ps pumps have remote reservoirs..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-27-2021, 01:28 PM   #8
SCOTI
SCOTI's Avatar
Interesting. New to me as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-28-2021, 12:08 AM   #9
Richard
Maybe the vehicle was a manual transmission and that nipple/hose runs to a clutch master cylinder. Personally I do not know of any consumer type vehicle that uses hydraulic brake fluid in the power steering system. While a hydroboost brake system does use the power steering pump, the brake fluid and power steering fluid are two separate circuits.
Richard
Old 07-28-2021, 02:11 AM   #10
mongocanfly
05 tahoes wernt manual trans...all autos
the LS3/TR6060 i pulled from a camaro did use a shared reservoir for the brake and clutch
after a whole lotta searching , i found where that hose hooks to some sorta canister that has another line coming from the proportioning valve ...
it dont hook to the power steering though.
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-28-2021, 02:43 AM   #11
mongocanfly
found it ....
part # 3 is called (brake pressure modulator valve)..part of antilock brake system
"The Brake Pressure Modulate Valve is a part of your vehicle's anti-lock braking system(ABS).
It is a device that is controlled by the electric signal that is generated by the ABS module.
The brake pressure modulate valve regulates the pressure that is supplied to each ABS controlled brake in the wheels."
https://chevroletforum.com/forum/tah...id-part-78138/
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-30-2021, 02:57 AM   #12
Richard
found it ....
Congrats on finding that. Was thinking it may have something to do with the ABS myself. I did find evidence that the Tahoe could be ordered with a manual trans.
Richard
Old 07-30-2021, 12:52 PM   #13
mongocanfly
(did find evidence that the Tahoe could be ordered with a manual trans.)
Really..??...
I thought the last manual trans stopped long before 05...that's interesting
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-31-2021, 10:24 AM   #14
v30crewcab
v30crewcab's Avatar
my tahoe has factory hydroboost. that line from the brake reservoir feeds the anti-lock brake setup.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 08-01-2021, 11:08 PM   #15
bfr57
bfr57's Avatar
Thanks all! Could've sworn that line from MC went to the HB, but obviously wrong! So, now I'm curious where the low pressure return line on the HB went on the Tahoe? I'm going to weld in an -6 AN return fitting into the PS reservoir and get a reservoir without that fitting and be done. Got an education lesson on this one!
