Old 07-31-2021, 02:19 AM   #1
Brettd85
Active Member
Factory tach not working with lq4
I’ve done some searching and read threads but there seems to be some inconsistent advice. My tach worked with hei ignition on my small block. This is a 71 c20 with factory tach. I installed a 6.0 lq4 and had the harness reworked by current performance. I connected the “tach” wire to the tach where the hei was hooked up. Not getting any reading. Some people say resistor, some people say I need a Dakota converter, others say program to 4 cylinder in hp tuners. Any advice is appreciated. Thanks!
Brettd85 is offline   Reply With Quote
Old 07-31-2021, 06:32 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Factory tach not working with lq4
I have heard about the 4 cyl setting. I have not tried it yet as my swap is not running yet. I just got my HP Tuners kit recently and am planning on using my factory tach. Mine is reproduction type tach though.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-31-2021, 11:23 AM   #3
ls1nova71
ls1nova71's Avatar
You won't need any kind of converter box to make it work if you have tuning software, which is needed to remove VATS anyway. What you need to do is change the tach resolution from 6 to 3 in the tune to change it to 8 cylinder instead of 4cylinder. That will make it read right, but only if it works in the first place. To make it work you will probably need a pull up resistor to strengthen the tach signal to the tach as some PCM's don't put out a strong enough signal to work an older tach. LT1Swap has a good write up on how to do this. https://lt1swap.com/lsx_tach.htm
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-02-2021, 01:28 PM   #4
tinydb84
tinydb84's Avatar
Kinda of a dumb question but did you disconnect any of the other wires from it? There are usually three: power, ground, signal.
David
Instagram: myfabguy
