07-31-2021, 05:43 PM | #1 |
power brake vacuum
ok, im working on my power brake up grade. wondering which port has the highest vacuum to hook the booster to - at the carb base or at the intake manifold runners?
engine is a basic 327 / 350 hp. thanks for the help.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
07-31-2021, 07:46 PM | #2 |
Re: power brake vacuum
The vacuum will be the same at either port. GM has used both locations over the years.
07-31-2021, 09:20 PM | #3 |
Do you already have a new power booster purchased? Frame mount?
07-31-2021, 09:42 PM | #4 |
That ^^^
1951 Chevy Panel Truck |
07-31-2021, 10:22 PM | #5 |
Ive got the frame mount booster & m/c installed. seems to work ok. Just wondering if I got the vacuum line hooked up to the proper port. there were no instructions with the kit
08-02-2021, 12:07 PM | #6 |
If the carb has a port on the back center to take the vacuum off for the booster that is where I would hook it up but some don't and off the 6/8 runner works equally well as far as vacuum to the booster goes.
08-03-2021, 12:07 AM | #7 |
you can also plumb in a vacuum reservoir with appropriate check valves so you have that added safety for the power brakes. remember back in the 70's where some manufacturers had those "tomato cans" plumbed in under the hood? well, something like that but with the appropriate sized inlet/outlet. look for a donor car with a/c or even a donor car with a/c and vac operated heater valves (like an astro van with rear where they used a plastic sphere vacuum storage cannister)
like said above by others, plumb into the base of the carb if available because it is less "pulsed" than a port runner would be. it will see all the cylinder pulses instead of just a couple like a port runner would see. some manifolds have a split plenum as well that affects the carb base vacuum. either way, use a good quality vac hose and clamps along with a tested check valve at the booster and possibly an inline filter you can find under the hood of a newer donor. steel/hard line will give better results on a long run than rubber line will but use some rubber in the area near the engine to allow for engine movement. hard line also looks cooler and more professional in my opinion. thats just my opinion though and it is YOUR truck. |
