08-11-2021, 03:34 AM | #1 |
Spark plug wire looms with vette rams horn manifolds
What are you fellas that are running ram horm manifolds using fot wire looms for your plugs . Looking for as stock appearing as possible.
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 08-11-2021 at 03:44 AM. |
08-11-2021, 03:59 AM | #2 |
Re: Spark plug wire looms with vette rams horn manifolds
You can use the Vette wires and lower shielding to keep the wires in place. They bolt to the small 1/4" holes drilled and tapped into the top of the block.
The parts are not overly expensive. Any vendor that sells Corvette parts will likely stock them. |
08-11-2021, 08:11 AM | #3 |
Classic parts has all of it . I used 76 Corvette hei wires
https://www.classicparts.com/1957-72...info/83%2D389/ https://www.classicparts.com/1958-69...info/83%2D386/ https://www.classicparts.com/1958-72...info/83%2D387/ https://www.classicparts.com/1958-72...info/83%2D388/
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-11-2021, 08:12 AM | #4 |
I,D like something more simple but thanks
I BELIEVE IN JOHN 3:16 |
08-11-2021, 08:18 AM | #5 |
grumpy, your engine is beautiful............who coated your mahifolds ? I polished mine and did a port -n-polish inside as far as i could reach. did you have clearence problems with the x-member or starter with the 2 1/2 in pipe
08-11-2021, 08:22 AM | #6 |
I had to use a combination of a few of each, the separator standoffs that attach to a valve cover bolt & the individual seperators. Also those little bitty zip ties are your friend to help hold wires back by loosely holding them toward dip stick tube or such. (I'll have to get pic this afternoon, if you want)
If you don't already have plug wires, get the ones you put the ends on yourself. Having that perfect length will make a big difference on how you can route & make them lay.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
08-11-2021, 08:33 AM | #7 |
i bought the 8 mm solid core u-fab wires from summit. i,am running a hei dist. pic,s would be super and appreciated
08-11-2021, 08:50 AM | #8 | |
The zoomed in pic (all I could find on my phone for now) is how I routed them on my current truck build - but they were pre-made length & about all I could do with them & where I had to use the stand offs.
08-11-2021, 09:54 AM | #9 | |
https://www.jegs.com/i/JEGS/555/3010...2/-1#reviewTab
08-11-2021, 02:54 PM | #10 |
thanks guys
08-11-2021, 10:14 PM | #11 |
I used the Made For You valve cover vertical looms and bolted them to the rear of the block where the factory loom attaches with the 4 wire loom, then used some washers the thickness of the oil pan lip and mounted the 3 wire and 2 wire looms in place of a couple of the oil pan bolts. This is a great setup that was not too expensive.
