#101 |
At the body shop.
Re: 2wd swap
Keeping a 17 yr old motivated is fun.
Baby step getting finished up
" That didnt make it any newer " " Dont antique the equipment " |
#102 |
At the body shop.
Re: 2wd swap
This kid is something else.
#103 |
Re: 2wd swap
I would agree. He's doing well. Especially for being a young-gun.
#104 |
At the body shop.
Re: 2wd swap
Not suspension related.
But weave aluminum? Seriously !?
#105 |
At the body shop.
Re: 2wd swap
Kids showed some initiative.
He wasn't feeling the 2 link plan. So triangulated 4 link it is. And was gifted this 9 inch housing. Got a 2.91 gear and a 31 spline locker for it.
#106 |
At the body shop.
Re: 2wd swap
Any reason not to do the upper links like this and the lower outside the rail?
#107 |
Re: 2wd swap
I did my uppers inside and lowers outside. Did it to push the bags out further.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#108 |
At the body shop.
Re: 2wd swap
Any pics ?
#109 |
Re: 2wd swap
http://67-72chevytrucks.com/vboard/s...&postcount=407
Lost a lot of pics due to Photobucket. This is probably the best pic.
#110 |
At the body shop.
Re: 2wd swap
Thanks.
I think we're gonna do a triangulated deal.
#111 |
At the body shop.
Re: 2wd swap
So no more 4 link thoughts?
Anyways back to the front end. We raised the upper pivot 1" and cycled the suspension 7 inches has -4° of camber change and 3/8 toe at full bump from ride height.
#112 |
At the body shop.
Re: 2wd swap
That escalated quickly.
#113 |
Re: 2wd swap
As long as the upper links have enough angle for keeping things centered, where the lowers go is likely decided by project packaging. Keeping the links & springs as far outboard as possible should be a benefit to stability. If there's room outboard of the frame, that's how I would do it.
#114 |
At the body shop.
Re: 2wd swap
Tentatively using the stock spring hanger as the lower link pivot.
And boxing the inside of the frame at the hanger for upper link off the diff housing.
#115 |
Re: 2wd swap
Using the OE hangers is how I'd do it as well. Sounds like a solid plan.
#116 |
At the body shop.
Re: 2wd swap
Kids wishful thinking
#117 |
Re: 2wd swap
I mean you already have the body off right...?
Whats a few inches between friends LOL (sorry had to..)
#118 |
Re: 2wd swap
Do it! Looks killer!!!
#119 |
At the body shop.
Re: 2wd swap
Some stuffs.
Raising the floor up 3" makes room for diff and suspension links.
#120 |
At the body shop.
Re: 2wd swap
Welding lots of Welding.
I think he is going to hate plumbing these. But the bag plates fit up was terrible so he cut them up and welded them in.
#121 |
At the body shop.
Re: 2wd swap
Bags look right ?
#122 |
Re: 2wd swap
Looks ok/normal to me.
#123 |
At the body shop.
Re: 2wd swap
Good, the bottom bolt is concerning me.
Looks like aired out it might drag/hit 1st
#124 |
At the body shop.
Re: 2wd swap
I believe the lower bag bolt won't be as much of a issue as these grease zerks.
#125 |
Re: 2wd swap
Wow. I'm guessing the engineers didnt plan on people laying out...
