Old 07-18-2004, 09:51 AM   #1
zstarkey
What do you think my truck will run
What do you think my truck will run in the quarter it is an 86 gmc sierra classic with a 415 horse 465 torque 388 stroker. it has 3.7.3 gears Just tell me what you think
zstarkey is offline   Reply With Quote
Old 07-18-2004, 01:29 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
14.5-15.5, My guess would be.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-18-2004, 05:14 PM   #3
gldevall
gldevall's Avatar
Mid to low 13's. Depending on traction.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 07-18-2004, 08:56 PM   #4
SanitysBane
im thinking that with the best traction, at sea leve, maybe 14.40s to 14.20s
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 07-19-2004, 02:23 AM   #5
78' Silverado
\/ My Loves \/
78' Silverado's Avatar
I'm gonig with 13's as well. Depends on weight..tires...you got enough power LOL. You got any fiberglass parts? Every lil bit of weight helps haha. But yea i say somehwre in the 13's.
78' Silverado - Blue - (In a Coma)
04' Silverado -Red-
383 Stroker in progress for the 78'!!!
78' Silverado is offline   Reply With Quote
Old 07-19-2004, 05:49 AM   #6
Nvbowtie
Nvbowtie's Avatar
Are those projected numbers or actual Dyno numbers, that will make the difference.
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 07-19-2004, 09:14 PM   #7
zstarkey
dyno
those numbers are dynoed numbers and no it is totally stock in the body department and the only real thin i have added is the engine and the traction bars the rearend is also a poistrac so that will have a little to do with it
Old 07-19-2004, 09:22 PM   #8
86 Red_Bowtie
86 Red_Bowtie's Avatar
I say it will run mid 13's . Depending on the power you can get to the ground and if it is a posi rearend wich will help get the power to the ground equally
86 Red_Bowtie is offline   Reply With Quote
Old 07-19-2004, 10:16 PM   #9
81shavedtrk
High 13's - low 14's But tranny, has alot to do with it. What size converter do you have? And is that a motor dyno or rear wheel dyno?
81shavedtrk is offline   Reply With Quote
Old 07-19-2004, 10:40 PM   #10
zstarkey
It is a motor Dyno and the tranny has a shift kit and corvette servo in it
Old 07-20-2004, 12:39 AM   #11
81shavedtrk
So its prolly like 360 hp and 410 ftlbs at the wheels. So yeah prolly low 14's high 13's. What trans does it have?
Old 07-20-2004, 02:16 PM   #12
TIMSPEED
TIMSPEED's Avatar
I would say 12's...a friend of mine put a ZZ4 into a 65 chevy SWB, and he put down a Nitrous-Fed LT1 Camaro! He never ran it at the track, because the thing simply COULD NOT hook.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 07-20-2004, 03:18 PM   #13
78' Silverado
\/ My Loves \/
No way 12's without nitrous. That motor running "all motor" will go low 14's high 13's now that i know its flywhell hp and not rwhp. Yea the pois will help and so will the 3.73's for sure but...theres no way that tuck will hit 12's unless its got a shot on it lol. ((no offence to the owner)) Sounds like a SWEET! truck. You better run it soon i wnna see some times man!
04' Silverado -Red-
Old 07-20-2004, 07:11 PM   #14
zstarkey
the truck will never have NOS and i run it this friday so you will have times soon i dont see it hittin 12's either im prayin for 13's
Old 07-20-2004, 07:18 PM   #15
zstarkey
I gotta whole new body and i got a 4-6 drop kit for it the drop is with upper and lower control arms and a flip kit, then im having the frame, the rearend, the leaf springs, the calipers all powdercoated. Stainless steel brake lines, four link rear suspenion, And it is going to be Reallllllllllllly dark green almost blackit will also have the conversion kit for the headlights then it will have 4.10 rear geard and 13's in the back
Old 07-20-2004, 10:57 PM   #16
ocbaud
Garage Queen Material
low to mid 14's is what i'm guessing
ocbaud is offline   Reply With Quote
Old 07-21-2004, 02:09 AM   #17
78' Silverado
\/ My Loves \/
I'ma make 2 guesses:
1. 13.96
2. 14.29
04' Silverado -Red-
Old 07-21-2004, 03:27 PM   #18
GMC AMI
GMC AMI's Avatar
Pipe dreams!
Good luck with your race against the clock! I think any faster than 14 sec. would be a pipe dream,by all means post a copy of your times and prove me wrong. Burn lots of rubber and run aviation fuel (jet fuel) for the best run. I hope you have good slicks,so you do not spin on launch. RUN HARD AND FAST!
GMC AMI is offline   Reply With Quote
Old 07-21-2004, 04:19 PM   #19
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Probably about high to mid 14's depending on traction and skills.
BTW: You need about 500hp to get to the 12's in a pickup.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-21-2004, 04:34 PM   #20
cochino12
It followed me home?
cochino12's Avatar
Maybe I missed it in the posts but are you going run it or what? I want to know dangit ha ha. I say high 13's. Good luck
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-21-2004, 06:34 PM   #21
Tom
driving is in my blood
Tom's Avatar
On radials it will do somthing in the 14's, with slicks and fantastic traction you'll get to 13.7 at best, to go lower needs more power.
Old 07-22-2004, 12:40 PM   #22
AirMale
AirMale's Avatar
I can't wait to see these times......tell me about the flip-kit, rear leafs and four link? That should really hook. We want the track slips scanned it so we can see all the details
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 07-22-2004, 12:51 PM   #23
gldevall
gldevall's Avatar
Seeing the amount of variance in the times everyone is saying has got me wondering....Who thinks my time is BS? 14.51 @ 91.01 with about 300 HP or so. Stock 350 8.5:1 with a 268H Comp cam. I'm not trying to start anything, but seeing that this guy says he has 415 HP and all he can get is high 13 seems funny. Any comments?
Old 07-22-2004, 01:13 PM   #24
AirMale
AirMale's Avatar
I have a comment: I love your avatar!
When I had my 383/450hp my best time was a 14.20 but keep in mind I had a 3.42posi and really ****ty pepboys 275/60/15 tires. Anyone who's ever actually gone to the track and ran their truck knows that all the power in the world doesn't equal low times. Your time represents an excellent run and I guess pretty decent 60ft times. I have to question sub 14 second times (SBC) without the use of either slicks or some type of traction device. I wish we could all meet at Atco raceway (NJ) tonight and find out what's working for everyone.
86 SWB 9.0 LITER
Old 07-22-2004, 04:02 PM   #25
gldevall
gldevall's Avatar
Yeah my 60' on that run was a 2.07. It just came off the line good. I want to get some 26" ET Streets and see how low I can get. I really need to tune my carb, as it is a Edel 1406 with elec choke that is calibrated for mileage. There may be a tenth or 2 in that.
Another big factor is altitude. Look at Cochino's time. He has a ZZ4 motor and cannot get into the 14's. I think he would be in the low 14 or high 13's if he would run it down here.
