Old 08-15-2021, 09:54 PM   #1
D-n-Tyke
Any difference between C10 & C20 Rearends?
Follow up to my other post in regards to front end differences. Thanks again for those reponses.
Now I am trying to figure out if there are any differences between a C10 and C20 rearend (other that the bolt pattern in the axle flange and drums) . Trying to convert from 8 lug to 5 lug. I know I can buy the conversion kit that comes with new axles and new drums, but I might have access to a 1970 C10 rearend. So if they are the same I think swapping the rear end might just be the easier.
D-n-Tyke is offline   Reply With Quote
Old 08-15-2021, 10:03 PM   #2
TurboThrift
Re: Any difference between C10 & C20 Rearends?
Hey there,
A C20 rearend is way different than what is found on a C10. The C20's will have a full floater 8 lug setup, either a Corporate HO52 or Dana 60. As far as I know, there is no aftermarket 5 lug conversion drums, axles, etc. for the axles mentioned above.
TurboThrift is offline   Reply With Quote
Old 08-15-2021, 10:17 PM   #3
D-n-Tyke
This was one of the kits I was looking at (although looking closer looks like it is for 6lug to 5 lug).
http://https://www.speedwaymotors.co...RoCAOsQAvD_BwE
Okay with that said, is that the only option I have to go from 8 lug to 5 lug is to swap the whole rear end?
Old 08-15-2021, 11:32 PM   #4
TurboThrift
Yes, that is correct. I'm sure you can find a donor 12 bolt diff from a 71-72 C10. Or if that isn't possible, a 6 lug to 5 lug swap (as you referenced) is fairly common.
On a side note, are you switching to 5 lug for wheel selection or for disc brakes?
Old 08-16-2021, 12:17 AM   #5
D-n-Tyke
So I have a potential lead on a 71 C10 "complete" front suspension (crossmember included) with with disk brakes and a complete rear axle from the same truck. I will have to see how much the guy is willing to deal. I think he might be asking a bit much right now at $700 (rear axle comes with trailing arms, springs and back half of the frame).
Yes, I am looking to switch from 8 lug to 5 kug for both reasons. Want disk breaks and I want to have some options for wheels.
Question for after I do this conversion. Are these C20 rearends in much demand?
Old 08-16-2021, 12:26 AM   #6
TurboThrift
I see. That sounds like a nice package deal if he's willing to negotiate.
And there is some value in that rear end, although it's a niche market. Finding good used 8 lug rears of this vintage is getting tough. Does yours have a locker/"No-Spin" unit?
Old 08-16-2021, 01:09 AM   #7
D-n-Tyke
Let's hope he is willing to negotiate. Make my life a lot easier with this conversion.
I am not sure if it has a locker or not (just pick this up a couple weeks ago). Would it be listed on the SPID? I will have to go out and look and see if I can find a tag on the rearend.
Old 08-16-2021, 01:22 AM   #8
Accelo
Accelo's Avatar
Yes....
However, things may have been switched out over the last 50 years.
Accelo is offline   Reply With Quote
Old 08-16-2021, 01:30 PM   #9
Big Kev-O
Big Kev-O's Avatar
You may be able to get a couple hundred $ for you 8 lug depending on the gear ratio and type but it could be a while before you find a buyer. My friend gave me a Eaton axle off his trailing arm truck and I posted it on Craigslist for free, luckily nobody picked it up because I removed the 4:10 Ring & Pinion and sold it on this website for $375. It sold a couple days after I listed it. Parts are not available for the Eatons so if you have the right gear ratio it can be worth some money.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 08-16-2021, 02:12 PM   #10
SkidmoreGarage
I was just barely able to give away a good Eaton 4.56 from a C20. I also sold a C20 Dana 60 3.56 (somewhere around that ratio) for $600.
The Eaton stuff just isn't available, or cheap, so the market is very small.
SkidmoreGarage is offline   Reply With Quote
Old 08-17-2021, 07:15 PM   #11
TurboThrift
I agree with the posters above. Your best bet is to post your old diff in the parts section and see what offers you get, you may be surprised.
Old 08-18-2021, 12:03 AM   #12
D-n-Tyke
Well the front suspension was sold before I could get there. But I did end up picking up the rear end, actually it was the whole back half of the frame (arms and springs) cut just forward of the trailing arm crossmember, and a set of steel wheels and tires. The whole shebang for $300. Figure not a smoking deal but one I could live with.
Now on to the hunt for a front suspension.
Old 08-18-2021, 05:15 AM   #13
Rears go in the $300 range. You did fine. You also have the extra parts to sell. The '70 rear is the last 6-lug but is the same width as the '71-ups. The rears got widened when disc brakes came out. You are all set. So this rear has been converted to 5-lug?
Old 08-18-2021, 10:51 AM   #14
D-n-Tyke
I was told the donor truck was a 1971 so it was already 5-lug.
Old 08-18-2021, 11:37 AM   #15
Big Kev-O
Big Kev-O's Avatar
You did excellent, a good set of trailing arms go for at least $250.
Old 08-18-2021, 01:21 PM   #16
D-n-Tyke
That is good to hear. I kept the trailing arms and the trailing arm mounting crossmember (with mounts). Going to junk the rest of the "half" frame as I assume all the other crossmembers are common and not worth anything.
