08-16-2021, 02:18 PM | #2026 |
Re: A '54 named Busty
a little spin on layinrocker65 idea of welding on the washers to keep the C lips from coming out, I decided to weld some on to the pins rather than attempting to mushroom the ends
08-16-2021, 02:19 PM | #2027 |
That works!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
08-16-2021, 05:25 PM | #2028 |
fellow truckers, lemme see if I can explain this situation so maybe you can help me
how tight are we supposed to make these hinges, I think I collapsed the pin on the rebuilt one just the way I found it so there is about 1/16 of an inch gap in the clam shell if you will, so is it supposed to be that loose or is it supposed to be zero lash ? |
08-16-2021, 08:01 PM | #2029 |
then it was time to repair the driver side top hinge
second verse same as the first but a whole lot messier and a whole lot worse |
08-16-2021, 08:04 PM | #2030 |
this one required more brainstrology
08-16-2021, 08:06 PM | #2031 |
so we procured the rustiest square a tubing we could find, this was gonna give us that right angle stopper piece
its wet cause I used water to cool it off after all the cutting Last edited by Gregski; 09-12-2021 at 09:54 AM. |
08-16-2021, 08:07 PM | #2032 |
and since no one will ever see this piece and never know what the repair looks like, I decided to spend many many hours making it as original as possible
08-16-2021, 08:08 PM | #2033 |
there, not too shabby, and once we spray it with some rust, no one will be the wiser
08-16-2021, 08:10 PM | #2034 |
and here I am drilling a pressure relief pilot hole in hopes of persuading that rusted pin out
08-16-2021, 09:49 PM | #2035 |
My hinges were at "zero" lash when I did them. I wanted everything to be as tight as possible.
53 GMC COE stock 53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949 '70 Chevy C10 LWB 350/sm465 74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
08-16-2021, 11:41 PM | #2036 |
08-16-2021, 11:42 PM | #2037 |
and the carnage begins
08-17-2021, 08:47 AM | #2038 |
Nice work on the hinge repair. Good luck on drilling out the pin.
08-19-2021, 09:06 AM | #2039 | |
Anyway... I would think you want those hinges pretty tight. That little bit of slop at the hinge will turn into a lot more at the latch.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
08-23-2021, 11:51 PM | #2040 |
so got crackin on the hinges some more, and things were going backwards quick
08-23-2021, 11:52 PM | #2041 |
a little blood, sweat, and spilled beers
08-24-2021, 12:00 AM | #2042 |
great tip, I took your advice
08-24-2021, 12:02 AM | #2043 |
and texter side done! feeling cute may shoot some paint on them later, IDK
08-24-2021, 12:04 AM | #2044 |
and in true Greg like fashion once again I got 3 out of 4 pieces done and decided to take a break!
08-24-2021, 12:25 AM | #2045 |
Those should work 👍🏻
08-25-2021, 12:17 AM | #2046 |
yay me got the fourth one done
08-25-2021, 12:19 AM | #2047 |
I tell you what doing things half @ss sucks, it just takes too long, all that sanding, wire wheelin' the rust, vacuuming it out, blowing it out, what happened to good ol' quality half @ss work, ha ha
08-25-2021, 12:20 AM | #2048 |
so after wire a wheelin' these bolts what do we use on them, loc tight or anti seizure?
08-25-2021, 12:13 PM | #2049 |
I used the “anti seizure” stuff
08-25-2021, 12:32 PM | #2050 |
