Old 08-16-2021, 08:40 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
WTB, I need a RH rear “big window” OEM stainless trim molding, badly
No really I had my stainless professionally polished, the RH rear piece doesn’t make the cut, and I’d take a LH side too or all three if nice.
Mint condition please, RH rear anyway. Surface scratches can be ironed out, I hoping for no bends or dings or so close. Shipping is a pain, please consider that into my cost for sure, I have an "open wallet" on this, I need to put this to bed, can't do that w/o a rear window.
Thank you
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-17-2021, 06:53 PM   #2
71CHEVYSHORTBED402
Re: WTB, I need a RH rear “big window” OEM stainless frame, badly
Ttt
Tony
Old 08-18-2021, 10:01 AM   #3
Grumpy old man
Grumpy old man's Avatar
SpecialK has a bunch of trim stashed away .What's wrong with the pieces you have ? I might be a buyer ?
Old 08-18-2021, 01:55 PM   #4
71CHEVYSHORTBED402
A little luck has it the RH piece I removed from the truck is probably good.
It wasn't serviced and needs some attention for an outer bend, which looks negligible to me. It has a minor dimple as well, otherwise good.........But I'm still looking for a replacement if one is out there, thanks for the lead.
The set I had polished was something I bought years ago. After polish they tell no lies, the RH side has four small dimples on the very top edge because why? Seems the wrong tool was used to remove it. It also has a small dimple near the lower edge of the top. I messed with that a little with some improvement, though perhaps it's my imagination. Only thing I've been able to come up with is a massage using a tapped up B/A flathead & heat..............
When it's said and done this piece should become available. I can take more pictures, but at the moment I'd like to resolve what I'm using first.
The shop said they couldn't repair the dimples because it's double walled............Hmm!
The LH side of what was polished has one minor dimple, same with the lower, but they're nice.
Tony
Old 08-18-2021, 04:08 PM   #5
Furno68C20
I have these.
67 C10 Fleetside SOLD
67 C10 SWB Fleetside
67 C20 Fleetside
68 C10 Fleetside
68 C20 Fleetside SOLD
72 k20
Pay Pal: Grant.Furneaux@gmail.com
Furno68C20 is offline   Reply With Quote
Old 08-18-2021, 07:13 PM   #6
Grumpy old man
^ That's ^ windshield and door panel trim ^ .
Old 08-19-2021, 01:43 AM   #7
71CHEVYSHORTBED402
I'll take it....... Kidding.
Tony
