08-24-2021, 03:07 PM | #1 |
Kickpanel ventilation
My kick panel vents don't feel like they bring in much air. Should you feel any air movement coming out while driving?
08-24-2021, 03:16 PM | #2 |
Re: Kickpanel ventilation
Is the cowl flapper open?
Yes you should feel movement if the flapper/door at the cowl is open. These vents are notorious for filling with leaves and debris. Could be clogged also. There is a thread here discussing cleaning them out.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
08-24-2021, 03:22 PM | #3 |
Yes they are open. Just not getting much air through them. Going to check for debris this evening. Just wanted to get someone to verify that they actually bring in a strong amount of air
08-24-2021, 04:05 PM | #4 |
I wouldn't say "strong". But I do get airflow and its better than when the vents are closed.
08-24-2021, 04:30 PM | #5 |
I get enough pressure from them being open that it is actually quieter in the cab with the vents open and the back window cracked. They allow a fair amount of air to circulate into the cab given that you have a window cracked open so the incoming air has some place to exit the cab.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
08-24-2021, 09:45 PM | #6 |
As stated above make sure the vent flap under the vent cowl on the passenger side is open. Since the vents don't have a fan drawing air in you need to create a draft by cracking a window.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
08-25-2021, 08:39 PM | #7 |
Where is the vent flap you are speaking of located?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
08-26-2021, 05:08 PM | #8 |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-27-2021, 07:17 AM | #9 |
08-27-2021, 07:42 AM | #10 |
Ah, ok. My truck does not have a/c.
09-03-2021, 11:55 AM | #11 |
You may have a bunch of crap that's plugging them up between the vent and the cowl. My truck fills up with tree seeds & debris, I don't have a screen.
When I first got it it was jammed full. Removed the cowl thing, air hose, a vacuum, and a piece of wire got it clean.
I got a bench seat baby, you don't have to sit over there. |
