Old 08-24-2021, 05:21 PM   #1
Tug87
LMC Steering column install
Hi all,
Hope you’re having a great week!
I’m in the middle of the LMC steering column install and have two quick questions.
1. I can’t seem to get the stewing spline bolt seated - see picture. Any helpful hints?
2. The column comes with a grey wire separate from the harness. I thought it could be for the horn but that spot looks filled. This is different than the stock setup. Any ideas on what this could be?
Tug87 is offline   Reply With Quote
Old 08-24-2021, 05:59 PM   #2
Tug87
Originally Posted by Tug87 View Post
Hi all,
Old 08-24-2021, 10:52 PM   #3
53burb
53burb's Avatar
Re: LMC Steering column install
you should post this in the truck section for more responses.....steering wheel and dash forward are the same as the trucks....the suspension and driveline is, also.....
53burb is offline   Reply With Quote
Old 08-25-2021, 12:01 PM   #4
Tug87
Thank you! Will do.
@53burb - do you have any more photos of the paint job on the suburban in your signature? Mine goes into paint next week and I'm thinking about going that route. Thanks!
Old 08-25-2021, 12:22 PM   #5
68 P.O.S.
Is the intermediate shaft on the bottom of the column all the way? When on correctly, the lower shaft of the column has a concave depression or cut out the bolt rests on. Maybe that's what's not lining up (the intermediate shaft and that bolt slot).
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-26-2021, 02:32 AM   #6
53burb
53burb's Avatar
Size:  38.6 KBhere is one...anything in particular u wanted??
Old 08-26-2021, 07:29 AM   #7
Tug87
That's perfect thank you! I'm going to send it to the painter and see what he thinks.
Old 08-26-2021, 08:17 AM   #8
53burb
53burb's Avatar
awesome!
Old 08-27-2021, 09:26 AM   #9
HO455
HO455's Avatar
If (And it is a big if) the new column is using factory colors for the wiring then a light gray wire may be for illumination of the shift indicator. It would splice into the dash light circuit.
The factory column used a fiber optic cable to light the shifter but the aftermarket may not.
This is just a assumption I made from my desk here in Oregon.
Good luck.
RIP Bob Parks.
