preferred brand of intank fuel pump 88 TBI 454
I need to order two new fuel pumps and sending units for my project truck(1988 gmc r3500 454 wTBI). What is everyone's preferred brand? I have twin tanks as well. Thank you in advance for any help on this.
Re: preferred brand of intank fuel pump 88 TBI 454
Walbro is good or maybe Edelbrock has a made in USA pump..
![]() Join Date: Feb 2004
I’ve always ordered GM or DELPHI from rockauto.
Active Member
![]() Join Date: Jan 2017
I also will only use AC Delco or Delphi - I have replaced too many Carter pumps and I only like to do that job once!
I always use the ep381 pump (96-up vortec) on my tbi trucks, have been since they came out, and have never had an issue. Some recommend the ep377 (94-95 454 tbi) but I would NOT use an ep386, which is what came in the truck. They barely supply enough fuel for a 350, much less a 454.
#6 | |
I’ve read that before, maybe from you
![]() Quote:
#7 | |
![]() Last edited by enonz65c30; 09-06-2021 at 11:35 AM. |
Delphi. Avoid GM pumps. Anything new is made in Mexico w/these. I installed both L/R new units on my dually (circa 2015) & both failed within months (<6). Swapped to Delphi's & no issues.
Duplicate deleted.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-14-2022 at 07:33 PM. |
#10 | |
@44th Miss Inf.... You mention the use of the later spec'd ep381 pump (96-up vortec) vs. the tbi spec'd pump. I thought the fuel psi was way different (<15psi/tbi vs 48-60psi/efi)?? What changes would be required to run one of these on a tbi truck?
#11 | |
I’ve never changed a thing, and never had an issue |
Ahh...... Thank you for the quik follow up. That opens up my fuel pump options. I'm going to try them/switch to these.
